Page 1 of 1
Minimum record time?
Posted: Tue Aug 16, 2005 9:21 pm
by blaxer
Is there such a thing as a minimum event record time? I have tried adjusting the buffers but it doesn't seem to do it. On some cameras I would like ZM to record a few seconds before and quite a few after the alarm event. TIA!!!
Posted: Tue Aug 16, 2005 9:28 pm
by jameswilson
you are rin the right area how many seconds pre alarm and post alarm do you want and at what framerate you capturing?
James
Posted: Tue Aug 16, 2005 11:49 pm
by blaxer
on most of the cameras I have the maximum fps set to 10 or 15, I would like something like 5-8 seconds before and around 30 seconds after. When I increase the buffers to what "should" be that ammount of frames I never get any events.
Posted: Thu Aug 18, 2005 5:25 am
by cordel
Increase to what you want and restart. You may have to adjust your shared memory and thats why you are not getting events. If you check the zmdc.log I bet you'll find shmget errors. See the FAQ.
Regards,
Cordel
