For the moment i've choosed a Cpia based (Trust spacecam 1000)
It's not a good cam but for 5 Euro...
work prefectly with cqcam, but under zm always crash with this error in /var/log/zm/zm/zmdc.log below.
The only way to have this camera "working" is to set the Palette to YUYV, but that's not aceptable because the image is completly pink and yellow.
i've set the Source exactly at 352x288 RGB24 to obtain the crash below.
from /var/log/zm/zm/zmdc.log
Starting pending process, zmc -d 0
'zmc -d 0' started at 05/08/18 16:36:49
'zmc -d 0' starting at 05/08/18 16:36:49, pid = 6792
'zmc -d 0' crashed at 05/08/18 16:36:49, exit status 255
here the Info of cqcam:
Type: 513
Can capture
Can capture subareas of the image
Channels: 1
Audios: 0
Maxwidth: 352
Maxheight: 288
Minwidth: 48
Minheight: 48
X: 0
Y: 0
Width: 352
Height: 288
Chromakey: 0
Flags: 0
Brightness: 32768 (128)
Hue: 32768 (128)
Color: 32768 (128)
Contrast: 32768 (128)
Whiteness: 0 (0)
Depth: 24
Palette: 4 - RGB24
here the output of zmu
# zmu -d /dev/video0 -v -q -P admin -U admin
Video Capabilities
Type: 513
Can capture
Video Channels: 1
Audio Channels: 0
Maximum Width: 352
Maximum Height: 288
Minimum Width: 48
Minimum Height: 48
Window Attributes
X Offset: 0
Y Offset: 0
Width: 88
Height: 72
Picture Attributes
Palette: 8 - YUYV
Colour Depth: 16
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
Aug 18 16:37:10 backup zmc_d0[6795]: INF [Debug Level = 0, Debug Log = <none>]
Aug 18 16:37:50 backup zmc_d0[6797]: INF [Debug Level = 0, Debug Log = <none>]
Aug 18 16:39:11 backup zmc_d0[6812]: INF [Debug Level = 0, Debug Log = <none>]
Aug 18 16:41:51 backup zmc_d0[6823]: INF [Debug Level = 0, Debug Log = <none>]
I've tried to to scale the resolution in Source with RGB24 whitout success.
any help will be apreciated.
best,
MaX
