I have zoneminder running at home & at work now, I'd like to use them each also as remote cameras for each other. I tried to put in the ip address 66.777.888.999 for ex, for host name, port 80, and what do I put for remote host path ? Both are on Fedora Core 4, both are V1.21.3 installed from rpm, and both work fine with local cameras. I have a bttv 4 port card at work & using the comp video input on HD3000 card at home.
Thanks !
How do I get a remote camera on 2nd ZM location?
OK, I do that & for location: I get a very long string:
http://XX.XX.XXX.188/cgi-bin/zm/zms?mode=
single&monitor=1&scale=100&auth=
334f14a76746a4c01cad137ccd395259&rand=
1124440311
I xxx'ed out my actual IP #'s there of couse, it also says:
Width 300px Height 200px
Size of File 8.33KB (8532 bytes)
Alternate text: Cam1.
I tried to put in just /cgi-bin/zm with & without the longer string that follows it for Source: Remote host path, but neither work.
I've got remote host port set to 80. Could this be an issue ? I've got a router & have set up zm ok to get http server through it, do I need to set up separate rule in the router for port 80 to go to that pc only ? or is there another path to look at or set up in the main options screen ? All I could find in the docs & faqs was in reference to if you have a network cam, but seems like I read a post how to do this, just can't seem to find it. Thanks !
1124440311
Try this post and see if it helps.
http://www.zoneminder.com/forums/viewto ... +pass+user
Regards,
Cordel
Regards,
Cordel
