Login broken
Posted: Fri Aug 19, 2005 7:59 pm
System: Debian Etch AMD64
Whe I try to login with any of the username/passwords in my database, I just get
the login screen redisplayed.
I can get a console by turning off authentication in the database, but that's unacceptable.
Trying to find where the failure occurs, I turned on debugging in zm.php. Below are the
php variables dumped after a login attempt. I notice that:
_SERVER["REQUEST_METHOD"] GET
even though the method in the sourece and in the access.log is POST.
_SERVER["QUERY_STRING"] no value
This is true in the access log -- there is no query string
_SERVER["argv"]
is empty.
This is the case with firefox and IE.
So my questions: Is this the reason for the login failure?
If so, where in the process are the login values likely not being forwarded?
Is my apache build whacked? or my php? or.....
If not, whare should I be looking?
Thanks.
Don
Variable Value
_REQUEST["bandwidth"] high
_REQUEST["format"] html
_REQUEST["ZMSESSID"] 46d6faae8e720027802eeec33f8b5983
_COOKIE["bandwidth"] high
_COOKIE["format"] html
_COOKIE["ZMSESSID"] 46d6faae8e720027802eeec33f8b5983
_SERVER["DOCUMENT_ROOT"] /var/www
_SERVER["HTTP_ACCEPT"] text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["HTTP_COOKIE"] bandwidth=high; format=html; ZMSESSID=46d6faae8e720027802eeec33f8b5983
_SERVER["HTTP_HOST"] zoneminder.mote.org
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_REFERER"] http://zoneminder.mote.org/zm/zm.php
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.7.8) Gecko/20050518 Firefox/1.0.4 (Debian package 1.0.4-2)
_SERVER["PATH"] /bin:/usr/bin:/usr/local/bin
_SERVER["REMOTE_ADDR"] 12.174.210.200
_SERVER["REMOTE_PORT"] 38016
_SERVER["SCRIPT_FILENAME"] /var/www/zm/zm.php
_SERVER["SERVER_ADDR"] 12.174.210.138
_SERVER["SERVER_ADMIN"] don@mote.org
_SERVER["SERVER_NAME"] zoneminder.mote.org
_SERVER["SERVER_PORT"] 80
_SERVER["SERVER_SIGNATURE"] <ADDRESS>Apache/1.3.33 Server at zoneminder.mote.org Port 80</ADDRESS>
_SERVER["SERVER_SOFTWARE"] Apache/1.3.33 (Debian GNU/Linux) PHP/4.3.10-15
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_URI"] /zm/zm.php
_SERVER["SCRIPT_NAME"] /zm/zm.php
_SERVER["PATH_TRANSLATED"] /var/www/zm/zm.php
_SERVER["PHP_SELF"] /zm/zm.php
_SERVER["argv"]
Array
_SERVER["argc"] 0
_ENV["LANG"] C
_ENV["PATH"] /bin:/usr/bin:/usr/local/bin
_SERVER["argv"]
is empty.
Thanks.
Don
Variable Value
_SERVER["argv"]
Array
_SERVER["argc"] 0
_ENV["LANG"] C
