ftp upload
ftp upload
after a bit of messing around i got ftp uploading working. Unfortunatly the machine has 12 cams on it and is set to mocord constantly. Obviously i am uploading lots and i think that i am capturing more than the machine can upload in time. Is there anyway to remove images from the upload. ie only upload images as if there were in modect mode. All i really want to upload is images where something is happening. I have adjusted to filter to only upload events with movement but in a 10 minute record they may be only 20 seconds of movement?
James
James
Hi James,
Something you might want to try is leave your mocord cams as is.
Set up dupplicate cams in modect mode and set your filters to those.
1. Driveway Mocord /dev/video0(0)
2. Frontdoor Mocord /dev/video0(1)
3. Driveway Modect /dev/video0(0)
4. Frontdoor Modect /dev/video0(1)
That way you only upload the actual events and can save the bandwidth.
Also maybe change your modect to strait record to conserve resorces but then you lose event loging with them.
Regards,
Cordel
Regards,
Cordel
My bad,
Just in case you actualy setup as I typed,
Should actualy read:
Also maybe change your mocord to strait record to conserve resorces but then you lose event loging with them.
Regards,
Cordel
Regards,
Cordel
The events are handled as a whole. You would have to find a way to decide what portion is actualy the frames you want. The database has a flag that it sets which is used in the frames detail page that could be used. But you also talking about coding that would have to be done in the filters to see that and building a fuction that would just package those frames based on the filter. I can't think of any other way at the moment. I'll ponder it a bit but I think this would have to go to the features request list as some bit of coding would need to be done.
Regards,
Cordel
Regards,
Cordel
back on topic.
I have a system that is set to ftp upload but for various resons the ftp server i was using is no longer available.
When i first set ftp upluad there were some perl packages missing and nothing uploaded. It cuased the background scripts to stall. Ie because it couldnt upload it stopped the purge when full filter working.
Now if the ftp server disappeared for whatever reason would this stall the script the same??
James
James
