Thanks b.addis for the advice on using Debian Stable. Installed once I upgraded libgcc1
Next problem is that when I click on the zm directory from a browser I get the download dialog. How do I make apache (not apache2) execute the php scripts?
I tried this
<Directory /var/www/zm>
Options +ExecCGI
</Directory>
but it still shows the download dialog after starting
Using Debian Stable 2.4.24
How to make Apache run PHP on Debian
Re: How to make Apache run PHP on Debian
if you haven't php4 running this mean that php4 is not installed. i think you need to install:
# apt-get install php4 php4-cgi php4-common php4-gd php4-mysql
ciao,
MaX
ciao,
MaX
