When authentication is enabled, then images do not load (eg., that broken image icon) from anywhere (browser on localhost or remote computer); also in this mode. (To be sure, yes, I do have full 'view' / 'edit' priv's enabled in options for the specified user.)
CLUE: I am NOT using authentication mode currently (obviously). But still, in open mode, the "Web" tab window of the options console does not finish loading in a remote browser. Mouse cursor is sitting there with an hourglass, and the last thing written on the page is "ZM_WEB_MONTAGE"... nothing to the right or below that. All other tab windows load. (Where are error logs stored?)
2. When I restart the machine, ZM IS running in the SUSE runlevel editor, BUT, in the console ZM is 'stopped'. Is there a configuration setting so that ZM runs again automatically after power failure / reboot?
Still needing help.... Thank you hugely!!
FYI: I now have two wireless cameras attached and working in mocord mode, via a 4-input BTTV card, on a 300MHz Gateway running SUSE 9.1. This part is very cool -- I'm using zoneminder! Back story: I had TWO bikes stolen from my car port in the same month (July) -- second time, somebody cut an expensive hefty motorcycle lock. I'm suspecting it is somebody in the neighborhood. Bait bike time. Thanks to ebay, for under 50 bucks, I've got two wireless pinhole cameras and a 4-input BTTV card. Right now one camera is watching the litter box (spying on my cat), but soon will be inside the car port watching my bait bike.
----- Original Message -----
So, it seems the reason I was getting "Forbidden" was because symlinks are forbidden (a friend found this in my apache error logs). So I made a hard link between index.php and zm.php, but I would rather have the correct way work, no telling what could happen if I fudge way of zm. So
1. Anybody know how to make symlinks allowable (and know why they are not)?
2. If I put zoneminder into authentication mode, images do not load (on a browser from anywhere, local or remote). I must turn off authentication to see / stream images.
3. Not directly related to zm, but I know this one will be easy for a linux gurus. I must type "modeprobe bttv" every time I restart the machine in order to activate my input card. How do I make that state stick? Thank you!!
Sincerely, Linux Novice (Suse 9.1)
Bruss
----- Original Message ----- (still some relevent questions.... anybody?)
[see my reply
