[solved] mixing BTTV 4chip/4ports with 1chip/4ports
- krzys31337
i've got one bttv0 with 4 channels and one bt878A, and added second card, with 4 ports and 4 channels.
Every card left alone works pretty well. Combining them seems to be problematic and neither of them work.
Using kernel 2.4.30 and ZM-1.21-3.
Anyone having similar problems/setup?
Best Regards and sorry for my poor english...
- zoneminder
- Site Admin
- Contact:
I've not done what you have so I don't know if there might be any basic reason for it not working. The only I can suggest is to try moving the cards around into different PCI slots and seeing if that makes a difference. Getting your modules.conf file right can also be a bit tricky for multiple cards.
Phil
Phil
- krzys31337
Done that.
Still no idea.
After many "shm get" error i've increased it by factor of 2 in /etc/sysctl.conf and 'sysctl -p' new setting.
In example bellow d0 and d1 are "4x1", d2..d5 are "4x4"
Aug 29 23:09:25 ola zmc_d3[4214]: WAR [Buffer overrun at index 21 ]
Aug 29 23:09:26 ola zmc_d1[3105]: WAR [Buffer overrun at index 21 ]
Aug 29 23:09:27 ola zmc_d5[5688]: WAR [Buffer overrun at index 21 ]
Aug 29 23:09:28 ola zmc_d2[3200]: WAR [Buffer overrun at index 21 ]
Aug 29 23:09:28 ola zma_m25[5647]: INF [Napoje: 026 - Starting new event 27267]
Aug 29 23:09:28 ola zma_m25[5647]: ERR [Can't insert frames: Duplicate entry '690054' for key 1]
Aug 29 23:09:29 ola zmc_d3[4214]: WAR [Buffer overrun at index 21 ]
Aug 29 23:09:30 ola zma_m26[5834]: INF [Debug Level = 0, Debug Log = <none>]
Aug 29 23:09:30 ola zma_m26[5834]: INF [Warming up]
Aug 29 23:09:30 ola zma_m26[5834]: WAR [Approaching buffer overrun, consider increasing ring buffer size]
Aug 29 23:09:31 ola zma_m26[5834]: INF [Fast_1: 026 - Starting new event 27268]
Aug 29 23:09:31 ola zma_m26[5834]: ERR [Can't insert frames: Duplicate entry '690054' for key 1]
Aug 29 23:09:31 ola zmc_d2[3200]: WAR [Buffer overrun at index 11 ]
Still no idea.
- krzys31337
it's here:
http://pancake.sggw.waw.pl/~hunter24/bttv/4xbt878a/
Don't know it's name, lspci says "4 generic pci cards", each one with bt878a and audio input.
Can't find it on http://pvrhw.goldfish.org/bttv/bttv-gallery.html
And in dmesg: 4 times this text:
Here http://www.allegro.pl/show_item.php?item=61626917 I've found similar card. (price is about 100 Euro)
03:0c.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 5
Memory at f2101000 (32-bit, prefetchable) [size=4K]
Capabilities: [44] Vital Product Data
Capabilities: [4c] Power Management version 2
03:0d.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 3
Memory at f2102000 (32-bit, prefetchable) [size=4K]
03:0d.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at f2103000 (32-bit, prefetchable) [size=4K]
03:0e.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 10
Memory at f2104000 (32-bit, prefetchable) [size=4K]
03:0e.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at f2105000 (32-bit, prefetchable) [size=4K]
03:0f.0 Multimedia video controller: Brooktree Corporation Bt878 Video Capture (rev 11)
Flags: bus master, medium devsel, latency 32, IRQ 7
Memory at f2106000 (32-bit, prefetchable) [size=4K]
03:0f.1 Multimedia controller: Brooktree Corporation Bt878 Audio Capture (rev 11)
Memory at f2107000 (32-bit, prefetchable) [size=4K]
bttv1: Bt878 (rev 17) at 03:0c.0, irq: 5, latency: 32, mmio: 0xf2100000
bttv1: using: *** UNKNOWN/GENERIC *** [card=0,insmod option]
bttv1: gpio: en=00000000, out=00000000 in=000fffff [init]
i2c-algo-bit.o: (0) scl=0, sda=0
i2c-algo-bit.o: bt878 #1 [sw] seems to be busy.
bttv: readee error
bttv1: using tuner=-1
bttv1: registered device video1
bttv1: registered device vbi1
bttv: Bt8xx card found (2).
- zoneminder
- Site Admin
- Contact:
- krzys31337
Solved:
Don't use any card=..., when mixing i use card=77,0,0,0,0.
First card is 4in1 and second is being treated as 4 separate cards.
Just for record: cart works pretty well. I've got ~20 fps on each port, and for "4in1" card 2-5 fps (while using more than one of four).
If someone would want any details please go ahead.
BTW mysqlcheck did that:
# Connecting to localhost...
zm.Config OK
zm.Controls OK
zm.Events OK
zm.Filters OK
zm.Frames
warning : Number of rows changed from 175406 to 175384
status : OK
zm.Groups OK
zm.Monitors OK
zm.States OK
zm.Stats OK
zm.TriggersX10 OK
zm.Users OK
zm.Zones OK
zm.Config OK
zm.Controls OK
zm.Events OK
zm.Filters OK
zm.Frames
status : OK
zm.Groups OK
zm.Monitors OK
zm.States OK
zm.Stats OK
zm.TriggersX10 OK
zm.Users OK
zm.Zones OK
1chip/4ports
How did you get zone minder see the four cameras with 1chip/4ports?
I´ve tryed a lot, but it just show the first camera. The others remain on black images.
1chip/4ports
I don´t have it installed now.
But I think I´ve put something like 0,1,2,3 in the devices.
It shows as if recognice the four cameras, but no images, except the first one.
I´ve installed from the cd live with mandrake 10.1.
The capture device was a generic bt878.
I think I will need really help.
robertomfrota@gmail.com
1chip/4ports
Well, I´ve just download the last version and I´ll try it next days.
but with a new capture board with 8 chips.
If I have any problems would you help me?
Just send me an email.
This is from Brazil.
thanks a lot anyway.
Roberto
Roberto
