hello dears,
i've installed zm in bebian. it seemsto work well. my webcam quickcampro lights first and after is off.
I'have changed seetting parameters and did some commands lines to be sure it recognised.
but no stream ........ any help, please ifyou know an issue.
I did search on forum, in particular the following. but no favorable suit for me!!
http://www.zoneminder.com/forums/viewtopic.php?t=4435
http://www.zoneminder.com/forums/viewtopic.php?t=4811
debian:/home/camera# lsusb
Bus 003 Device 001: ID 0000:0000
Bus 002 Device 005: ID 046d:08b2 Logitech, Inc. QuickCam Pro 4000
Bus 002 Device 004: ID 1241:1111 Belkin Mouse
Bus 002 Device 001: ID 0000:0000
Bus 001 Device 001: ID 0000:0000
debian:/home/camera# dmesg
ailed.
...trying to set up timer as ExtINT IRQ... works.
Using local APIC timer interrupts.
calibrating APIC timer ...
..... CPU clock speed is 1808.0511 MHz.
..... host bus clock speed is 200.0945 MHz.
checking if image is initramfs...it isn't (ungzip failed); looks like an initrd
Freeing initrd memory: 4216k freed
NET: Registered protocol family 16
EISA bus registered
PCI: PCI BIOS revision 2.10 entry at 0xf0031, last bus=2
PCI: Using configuration type 1
mtrr: v2.0 (20020519)
ACPI: Subsystem revision 20040326
ACPI: Interpreter enabled
ACPI: Using IOAPIC for interrupt routing
ACPI: PCI Root Bridge [PCI0] (00:00)
PCI: Probing PCI hardware (bus 00)
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.P0P1._PRT]
ACPI: Power Resource [ISAV] (on)
ACPI: PCI Interrupt Link [LNKA] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKB] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LNKC] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKD] (IRQs 16 17 18 19) *0, disabled.
ACPI: PCI Interrupt Link [LNKE] (IRQs 16 17 18 19) *11
ACPI: PCI Interrupt Link [LUS0] (IRQs 20 21 22) *3
ACPI: PCI Interrupt Link [LUS1] (IRQs 20 21 22) *9
ACPI: PCI Interrupt Link [LUS2] (IRQs 20 21 22) *10
ACPI: PCI Interrupt Link [LKLN] (IRQs 20 21 22) *9
ACPI: PCI Interrupt Link [LAUI] (IRQs 20 21 22) *10
ACPI: PCI Interrupt Link [LKMO] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [LKSM] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [LTID] (IRQs 20 21 22) *0
ACPI: PCI Interrupt Link [LTIE] (IRQs 20 21 22) *0, disabled.
ACPI: PCI Interrupt Link [LATA] (IRQs 20 21 22) *14
Linux Plug and Play Support v0.97 (c) Adam Belay
PnPBIOS: Scanning system for PnP BIOS support...
PnPBIOS: Found PnP BIOS installation structure at 0xc00f5400
PnPBIOS: PnP BIOS version 1.0, entry 0xf0000:0x611a, dseg 0xf0000
pnp: 00:0b: ioport range 0x4d0-0x4d1 has been reserved
pnp: 00:0b: ioport range 0xcf8-0xcff could not be reserved
pnp: 00:0b: ioport range 0x480-0x4ff could not be reserved
PnPBIOS: 16 nodes reported by PnP BIOS; 16 recorded by driver
PCI: Using ACPI for IRQ routing
ACPI: PCI Interrupt Link [LKSM] enabled at IRQ 22
ACPI: PCI interrupt 0000:00:01.1[A] -> GSI 22 (level, low) -> IRQ 169
ACPI: PCI Interrupt Link [LUS0] enabled at IRQ 21
ACPI: PCI interrupt 0000:00:02.0[A] -> GSI 21 (level, low) -> IRQ 177
ACPI: PCI Interrupt Link [LUS1] enabled at IRQ 20
ACPI: PCI interrupt 0000:00:02.1 -> GSI 20 (level, low) -> IRQ 185
ACPI: PCI Interrupt Link [LUS2] enabled at IRQ 22
ACPI: PCI interrupt 0000:00:02.2[C] -> GSI 22 (level, low) -> IRQ 169
ACPI: PCI Interrupt Link [LKLN] enabled at IRQ 21
ACPI: PCI interrupt 0000:00:05.0[A] -> GSI 21 (level, low) -> IRQ 177
ACPI: PCI Interrupt Link [LAUI] enabled at IRQ 20
ACPI: PCI interrupt 0000:00:06.0[A] -> GSI 20 (level, low) -> IRQ 185
ACPI: PCI Interrupt Link [LTID] BIOS reported IRQ 0, using IRQ 22
ACPI: PCI Interrupt Link [LTID] enabled at IRQ 22
ACPI: PCI interrupt 0000:00:0a.0[A] -> GSI 22 (level, low) -> IRQ 169
ACPI: PCI Interrupt Link [LNKE] enabled at IRQ 19
ACPI: PCI interrupt 0000:01:00.0[A] -> GSI 19 (level, low) -> IRQ 193
ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 18
ACPI: PCI interrupt 0000:02:07.0[A] -> GSI 18 (level, low) -> IRQ 201
number of MP IRQ sources: 15.
number of IO-APIC #1 registers: 24.
testing the IO APIC.......................
IO APIC #1......
.... register #00: 01000000
....... : physical APIC id: 01
....... : Delivery Type: 0
....... : LTS : 0
.... register #01: 00170011
....... : max redirection entries: 0017
....... : PRQ implemented: 0
....... : IO APIC version: 0011
.... register #02: 01000000
....... : arbitration: 01
.... IRQ redirection table:
NR Log Phy Mask Trig IRR Pol Stat Dest Deli Vect:
00 000 00 1 0 0 0 0 0 0 00
01 001 01 0 0 0 0 0 1 1 39
02 000 00 1 0 0 0 0 0 0 00
03 001 01 0 0 0 0 0 1 1 41
04 001 01 0 0 0 0 0 1 1 49
05 001 01 0 0 0 0 0 1 1 51
06 001 01 0 0 0 0 0 1 1 59
07 001 01 1 0 0 0 0 1 1 61
08 001 01 0 0 0 0 0 1 1 69
09 001 01 0 1 0 0 0 1 1 71
0a 001 01 0 0 0 0 0 1 1 79
0b 001 01 0 0 0 0 0 1 1 81
0c 001 01 0 0 0 0 0 1 1 89
0d 001 01 0 0 0 0 0 1 1 91
0e 001 01 0 0 0 0 0 1 1 99
0f 001 01 0 0 0 0 0 1 1 A1
10 000 00 1 0 0 0 0 0 0 00
11 000 00 1 0 0 0 0 0 0 00
12 001 01 1 1 0 1 0 1 1 C9
13 001 01 1 1 0 1 0 1 1 C1
14 001 01 1 1 0 1 0 1 1 B9
15 001 01 1 1 0 1 0 1 1 B1
16 001 01 1 1 0 1 0 1 1 A9
17 000 00 1 0 0 0 0 0 0 00
Using vector-based indexing
IRQ to pin mappings:
IRQ0 -> 0:2
IRQ1 -> 0:1
IRQ3 -> 0:3
IRQ4 -> 0:4
IRQ5 -> 0:5
IRQ6 -> 0:6
IRQ7 -> 0:7
IRQ8 -> 0:8
IRQ9 -> 0:9
IRQ10 -> 0:10
IRQ11 -> 0:11
IRQ12 -> 0:12
IRQ13 -> 0:13
IRQ14 -> 0:14
IRQ15 -> 0:15
IRQ201 -> 0:18
IRQ193 -> 0:19
IRQ185 -> 0:20
IRQ177 -> 0:21
IRQ169 -> 0:22
.................................... done.
VFS: Disk quotas dquot_6.5.1
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
devfs: 2004-01-31 Richard Gooch (rgooch@atnf.csiro.au)
devfs: boot_options: 0x0
Initializing Cryptographic API
isapnp: Scanning for PnP cards...
isapnp: No Plug & Play device found
Serial: 8250/16550 driver $Revision: 1.90 $ 54 ports, IRQ sharing enabled
ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
RAMDISK driver initialized: 16 RAM disks of 8192K size 1024 blocksize
serio: i8042 AUX port at 0x60,0x64 irq 12
serio: i8042 KBD port at 0x60,0x64 irq 1
input: AT Translated Set 2 keyboard on isa0060/serio0
EISA: Probing bus 0 at eisa0
Cannot allocate resource for EISA slot 5
EISA: Detected 0 cards.
NET: Registered protocol family 2
IP: routing cache hash table of 8192 buckets, 64Kbytes
TCP: Hash tables configured (established 262144 bind 65536)
NET: Registered protocol family 8
NET: Registered protocol family 20
ACPI: (supports S0 S1 S3 S4 S5)
RAMDISK: cramfs filesystem found at block 0
RAMDISK: Loading 4216 blocks [1 disk] into ram disk... done.
VFS: Mounted root (cramfs filesystem) readonly.
Freeing unused kernel memory: 204k freed
vesafb: probe of vesafb0 failed with error -6
Uniform Multi-Platform E-IDE driver Revision: 7.00alpha2
ide: Assuming 33MHz system bus speed for PIO modes; override with idebus=xx
NFORCE3-250: IDE controller at PCI slot 0000:00:08.0
NFORCE3-250: chipset revision 162
NFORCE3-250: not 100% native mode: will probe irqs later
NFORCE3-250: BIOS didn't set cable bits correctly. Enabling workaround.
NFORCE3-250: 0000:00:08.0 (rev a2) UDMA133 controller
ide0: BM-DMA at 0xffa0-0xffa7, BIOS settings: hda:DMA, hdb:pio
ide1: BM-DMA at 0xffa8-0xffaf, BIOS settings: hdc:DMA, hdd:pio
hda: Maxtor 6Y080L0, ATA DISK drive
Using anticipatory io scheduler
ide0 at 0x1f0-0x1f7,0x3f6 on irq 14
hda: max request size: 128KiB
hda: 160086528 sectors (81964 MB) w/2048KiB Cache, CHS=65535/16/63, UDMA(133)
/dev/ide/host0/bus0/target0/lun0: p1 p2 < p5 >
hdc: HL-DT-ST GCE-8526B, ATAPI CD/DVD-ROM drive
ide1 at 0x170-0x177,0x376 on irq 15
kjournald starting. Commit interval 5 seconds
EXT3-fs: mounted filesystem with ordered data mode.
Adding 2321352k swap on /dev/hda5. Priority:-1 extents:1
EXT3 FS on hda1, internal journal
hdc: ATAPI 52X CD-ROM CD-R/RW drive, 2048kB Cache, UDMA(33)
Uniform CD-ROM driver Revision: 3.20
Capability LSM initialized
device-mapper: 4.1.0-ioctl (2003-12-10) initialised: dm@uk.sistina.com
3c59x: Donald Becker and others. www.scyld.com/network/vortex.html
0000:02:07.0: 3Com PCI 3c905B Cyclone 100baseTx at 0xbc00. Vers LK1.1.19
SCSI subsystem initialized
libata version 1.02 loaded.
sata_nv version 0.02
PCI: Setting latency timer of device 0000:00:0a.0 to 64
ata1: SATA max UDMA/133 cmd 0x9F0 ctl 0xBF2 bmdma 0xC800 irq 169
ata2: SATA max UDMA/133 cmd 0x970 ctl 0xB72 bmdma 0xC808 irq 169
ata1: no device found (phy stat 00000000)
scsi0 : sata_nv
ata2: no device found (phy stat 00000000)
scsi1 : sata_nv
Linux agpgart interface v0.100 (c) Dave Jones
agpgart: Detected AGP bridge 0
agpgart: Setting up Nforce3 AGP.
agpgart: Maximum main memory to use for agp memory: 690M
agpgart: AGP aperture is 128M @ 0xf0000000
usbcore: registered new driver usbfs
usbcore: registered new driver hub
ohci_hcd: 2004 Feb 02 USB 1.1 'Open' Host Controller (OHCI) Driver (PCI)
ohci_hcd: block sizes: ed 64 td 64
ohci_hcd 0000:00:02.0: PCI device 10de:00e7 (nVidia Corporation)
PCI: Setting latency timer of device 0000:00:02.0 to 64
ohci_hcd 0000:00:02.0: irq 177, pci mem f09da000
ohci_hcd 0000:00:02.0: new USB bus registered, assigned bus number 1
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 4 ports detected
ohci_hcd 0000:00:02.1: PCI device 10de:00e7 (nVidia Corporation)
PCI: Setting latency timer of device 0000:00:02.1 to 64
ohci_hcd 0000:00:02.1: irq 185, pci mem f09dc000
ohci_hcd 0000:00:02.1: new USB bus registered, assigned bus number 2
hub 2-0:1.0: USB hub found
hub 2-0:1.0: 4 ports detected
usb 2-1: new low speed USB device using address 2
usb 2-2: new full speed USB device using address 3
usbcore: registered new driver hiddev
input: USB HID v1.00 Mouse [1241:1111] on usb-0000:00:02.1-1
usbcore: registered new driver usbhid
drivers/usb/input/hid-core.c: v2.0:USB HID core driver
Linux video capture interface: v1.00
mice: PS/2 mouse device common for all mice
pwc Philips webcam module version 9.0.1 loaded.
pwc Supports Philips PCA645/646, PCVC675/680/690, PCVC720[40]/730/740/750 & PCVC830/840.
pwc Also supports the Askey VC010, various Logitech Quickcams, Samsung MPC-C10 and MPC-C30,
pwc the Creative WebCam 5 & Pro Ex, SOTEC Afina Eye and Visionite VCS-UC300 and VCS-UM100.
pwc Logitech QuickCam 4000 Pro USB webcam detected.
pwc Registered as /dev/video0.
usbcore: registered new driver Philips webcam
usbaudio: device 3 audiocontrol interface 1 has 1 input and 0 output AudioStreaming interfaces
usbaudio: valid input sample rate 44100
usbaudio: device 3 interface 2 altsetting 1: format 0x00000010 sratelo 44100 sratehi 44100 attributes 0x00
usbaudio: valid input sample rate 22050
usbaudio: device 3 interface 2 altsetting 2: format 0x00000010 sratelo 22050 sratehi 22050 attributes 0x00
usbaudio: valid input sample rate 11025
usbaudio: device 3 interface 2 altsetting 3: format 0x00000010 sratelo 11025 sratehi 11025 attributes 0x00
usbaudio: valid input sample rate 8000
usbaudio: device 3 interface 2 altsetting 4: format 0x00000010 sratelo 8000 sratehi 8000 attributes 0x00
usbaudio: registered dsp 14,3
usbaudio: constructing mixer for Terminal 3 type 0x0101
usbaudio: warning: found 1 of 0 logical channels.
usbaudio: assuming the channel found is the master channel (got a Philips camera?). Should be fine.
usbaudio: registered mixer 14,0
usb_audio_parsecontrol: usb_audio_state at ef054f20
usbcore: registered new driver audio
drivers/usb/class/audio.c: v1.0.0:USB Audio Class driver
ts: Compaq touchscreen protocol output
usbcore: registered new driver snd-usb-audio
ehci_hcd 0000:00:02.2: PCI device 10de:00e8 (nVidia Corporation)
PCI: Setting latency timer of device 0000:00:02.2 to 64
ehci_hcd 0000:00:02.2: irq 169, pci mem f0a25c00
ehci_hcd 0000:00:02.2: new USB bus registered, assigned bus number 3
PCI: cache line size of 64 is not supported by device 0000:00:02.2
ehci_hcd 0000:00:02.2: USB 2.0 enabled, EHCI 1.00, driver 2004-May-10
hub 3-0:1.0: USB hub found
hub 3-0:1.0: 8 ports detected
usb 2-1: USB disconnect, address 2
usb 2-2: USB disconnect, address 3
usbaudio: unregister dsp 14,3
usbaudio: unregister mixer 14,0
forcedeth.c: Reverse Engineered nForce ethernet driver. Version 0.29.
PCI: Setting latency timer of device 0000:00:05.0 to 64
ohci_hcd 0000:00:02.1: wakeup
eth1: forcedeth.c: subsystem: 01043:80a7 bound to 0000:00:05.0
usb 2-1: new low speed USB device using address 4
usb 2-2: new full speed USB device using address 5
usbaudio: device 5 audiocontrol interface 1 has 1 input and 0 output AudioStreaming interfaces
usbaudio: device 5 interface 2 altsetting 1: format 0x00000010 sratelo 44100 sratehi 44100 attributes 0x00
usbaudio: device 5 interface 2 altsetting 2: format 0x00000010 sratelo 22050 sratehi 22050 attributes 0x00
usbaudio: device 5 interface 2 altsetting 3: format 0x00000010 sratelo 11025 sratehi 11025 attributes 0x00
usbaudio: device 5 interface 2 altsetting 4: format 0x00000010 sratelo 8000 sratehi 8000 attributes 0x00
usb_audio_parsecontrol: usb_audio_state at ef054760
PCI: Setting latency timer of device 0000:00:06.0 to 64
intel8x0_measure_ac97_clock: measured 49263 usecs
intel8x0: clocking to 46824
cpci_hotplug: CompactPCI Hot Plug Core version: 0.2
pci_hotplug: PCI Hot Plug PCI Core version: 0.5
pciehp: PCI Express Hot Plug Controller Driver version: 0.4
shpchp: shpc_init : shpc_cap_offset == 0
shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
Real Time Clock Driver v1.12
input: PC Speaker
inserting floppy driver for 2.6.8-2-386
Floppy drive(s): fd0 is 1.44M
FDC 0 is a post-1991 82077
parport: PnPBIOS parport detected.
parport0: PC-style at 0x378 (0x778), irq 7, dma 3 [PCSPP,TRISTATE,COMPAT,ECP,DMA]
NET: Registered protocol family 17
NET: Registered protocol family 5
NET: Registered protocol family 10
Disabled Privacy Extensions on device c02cc960(lo)
IPv6 over IPv4 tunneling driver
eth0: no IPv6 routers present
pwc Failed to set LED on/off time.
pwc set_video_mode(176x144 @ 10, palette 15).
pwc decode_size = 1.
pwc set_video_mode(160x120 @ 10, palette 15).
debian:/home/camera# xawtv -device /dev/video0
This is xawtv-3.94, running on Linux/i686 (2.6.8-2-386)
/dev/video0 [v4l]: no overlay support
v4l-conf had some trouble, trying to continue anyway
Warning: Cannot convert string "-*-ledfixed-medium-r-*--39-*-*-*-c-*-*-*" to type FontStruct
config: invalid value for input: Television
valid choices for "input": "Webcam"
ioctl: VIDIOCMCAPTURE(frame=0;height=120;width=160;format=5): Argument invalide
ioctl: VIDIOCMCAPTURE(frame=0;height=120;width=160;format=4): Argument invalide
ioctl: VIDIOCMCAPTURE(frame=0;height=120;width=160;format=1): Argument invalide
ioctl: VIDIOCMCAPTURE(frame=0;height=120;width=160;format=7): Argument invalide
ioctl: VIDIOCMCAPTURE(frame=0;height=120;width=160;format=13): Argument invalide
ioctl: VIDIOCMCAPTURE(frame=0;height=288;width=352;format=15): Aucun fichier ou répertoire de ce type
debian:/home/camera# xawtv -c/dev/video0 -geometry 320x240
ioctl: VIDIOCMCAPTURE(frame=0;height=240;width=320;format=15): Aucun fichier ou répertoire de ce type
station "-c/dev/video0" not found
if you need else info to help me, let me know.
thanks a lot!
logitech qickcampro4000
- zoneminder
- Site Admin
- Contact:
I'm running in Fedora Core 4 but I have the same problem with the same model of camera, the culprit was the driver in the kernel, so I have to download a driver from hhttp://www.saillard.org/linux/pwc/files and instructions are in http://www.saillard.org/linux/pwc/INSTALL.en
