reciever software
Im thinking dedicated linux server listening on whatever ports
In the event of a trigger from a site zm it connect to reciever server.
Then web page from reciever server showing current activations
I assume that the alarm signal that shows in a viewing page (which appears instant) could be used to send alarms
Then once alarm has been acknowledged site zm would disconnect and carry on doing what it does.
Big project i know but would be a way to get multiple zm sites to communicate to a central place only when they needed to. On top of this there would need to be link monitoring etc. I am currently testing nagios for this. As it polls each zm site if there was a failure it emails a set user this user would then need to manually connect to site and check path etc etc.
James
Reciever
The status you refer to it refreashed though the web page at a cycle determined by the settings you have in you bandwidth configs (low, medium, high). You could have a remote fetch server fetch these.
I think what would be better would be to look at making a wraper for zm that could get that information and send it via a udp or tcp packet for the current status.
Just my two cents.
Regards,
Cordel
Just my two cents.
Regards,
Cordel
