Noise lines during capturing
Ciccio
Post by Ciccio »
I installed latest MDK LiveCD with a one Conexant chip and 4 inputs capture card.
If I see monitor in higher resolutions (surely >=640x480) in RGB* mode I got a lot of noise horizontal lines when ther's movement in the image.
It's a Zoneminder fault cause I get an excellent image if I look it at 640x480 or more with xawtv (or tvsomething can't remember well).
Setting grab image to 352x288 or less I don't get any artifact.
What could cause the problem? I get those lines even in stil frames so it's as zmc can't capture correctly frames at those resolutions.
Machine is a P4 2.4 Ghz with 512 MB Ram and I'm usting it with only one cam so I don't think it's a load problem (load is variable from 0,5 to 1.2, with X running).
Francesco
jameswilson
Post by jameswilson »
xawtv, tvtime etc use deinterlacing techniques to stop this happening.
This is a common question use the search the fourum buttin and search for interlace
http://www.zoneminder.com/forums/viewto ... =interlace will get you started
Some chips are better than others but if you are getting 'combing' even without movement, lazyleopard wrote a nice mod that phil added in 1.21.3
The setting is in options somewhere
James
Ciccio
Post by Ciccio »
Thanks I've founded that options and I'm updating zm (I had 1.21.0), I tried to search on forum but I didn't know how this effect was called.
Try to solve with this options and let you know...
jameswilson
i have just seen the picture from your first post dont know how i missed it. Unfortunatly what im talking about wont help. That looks like a hardware problem in the camera. Have you tried pluging it into a std monitor?
James
ps sorry for the wrong info i gave ya
Ciccio
Post by Ciccio »
As I told in the post the problems doesn't occurs if I see images in tvtime: I got a fluid full framerate video without artifacts. But when I go in zm that's what I got around "moving" objects if resolution is more than 352x288.
Ciccio
Post by Ciccio »
Tried upgrading to 1.21.3 and using that options but nothing changed. I'll try changing my cable/videosource.
zoneminder
Site Admin
Post by zoneminder »
As I've just mentioned in another reply strangely enough, xawtv etc in normal mode just use a memory mapping technique to map the video memory to screen memory. In order to analyse an image ZM (and other applications) have to grab each frame separate using a different method. In xawtv you can simulate this by doing a few image/frame grabs and saving and examining those images.
I would be interested to see whether any of those images exhibit the same problem. A couple more example images might also be useful.
Phil
Ciccio
Post by Ciccio »
I did as you said, grabbing some images with tvtime and I got these results:
and
So none of those strange lines appears here.
Hope to be useful to you to understand some more than I do!
Ciccio
Post by Ciccio »
I didn't still solved but I'm now trying to see if it happens with a different bttv grab card (It's a TV Card I've got). Let you know soon.
Phil as you see with tvtime I don't have such noise, have you got some idea about that problem? It's something only I have to fight with or you already had seen something similar?
Ciccio
Post by Ciccio »
I've found some more info about the card I'm using. It's a Hawell DVR Card Hw-104, you can find some specs here:
http://www.alibaba.com/catalog/10985937 ... w_104.html
I tried using 768x288 and lines disappeared. So that problems seems visible when vertical resolution is > 288... (as you can see in screenshot they appears only in the first half of the image, never below, I forgot to say this particular in my post).
RedFlyer
Post by RedFlyer »
This card is also known as PICO2000. They are lot of clone all over the world :wink:
Why do you want to use it in a resolution higher then 384*288 ?
Personnaly, for CCTV it's more than enough.
Regards,
Oliver
________
Mercedes-Benz 200 History
jameswilson
i would like to capture above that res for number plates recognition etc i am looking at going the ip route to achieve this
James
Ciccio
Post by Ciccio »
jameswilson hit the point!
I need to have enought resolution to make plate recognition (manual looking at events and when I'll find a software I can use with zoneminder by sw).
Maybe the card isn't the best choice and maybe I'll change it but I'd like to use all its potential before trashing it! :D
jameswilson
i think if you feed progressive scan into it you should be ok. I am supposed to be testing this. Else go for IP camera. Im gonna trial a 206M to see how megapixel performs as i think this is the way to go. Unfortunatly is zm is analysing images of this size i think the overhead maybe too high. Someone else came up with the grat idea of sampling down to a low res just for movement analysis. If Phil impliments this then this will without doubt be the way to go.
James
jameswilson
I have just gained another old machine and am having this problem now. What mobo u using?
