Hi, All
This is my first time to install zm. Following the instruction of installation, i got the zm service start without error. But when i open firefox browser to http://localhost/zm, the following error message pop up:
Could not connect to database: Can't connect to local MySql server through socket 'var/lib/mysql/mysql.sock'
mysqld and httpd services have been started successfully.
Anyone can help me to figure out this installation problem?
tomlj
Cann't view zm via firefox
which method did you use to install it?
what's your system??
just to compare with the install test i did on different systems
But acording to the error message, something is bad with mysql components.
may be:
1- libmysqlclient?
2- have you runned zminit?
3-php-mysql, perlmodules,?
----> try connect to localhost only, and see if you can see apache homepage to be sure no pb whith apache....
I met similar error untilli have installed zm without error. what i did is to install phpmyadmin (on debian apt-get install phpmyadmin), and this installed someother packages to fix dependences, and the error was fixed. today, not know really te pb I had, but it worksfine now!!
regards
may be:
1- libmysqlclient?
regards
mk
Hi, All
Thanks for your reply.
My system is Fedora core 3.
I am trying to use zm rpm to install zoneminder.
All the required rpm are downloaded and installed from ftp://download.computerntelecom.com/pub ... xtra-RPMS/.
The error logs are attached, please help me to figure out the problem.
MK: I installed phpmyadmin. but the problem remains.
Thanks in advance for your kind help.
MySQL server log is:
050912 23:11:40 mysqld started
Cannot initialize InnoDB as 'innodb_data_file_path' is not set.
If you do not want to use transactional InnoDB tables, add a line
skip-innodb
to the [mysqld] section of init parameters in your my.cnf
or my.ini. If you want to use InnoDB tables, add to the [mysqld]
section, for example,
innodb_data_file_path = ibdata1:10M:autoextend
But to get good performance you should adjust for your hardware
the InnoDB startup options listed in section 2 at
http://www.innodb.com/ibman.html
/usr/libexec/mysqld: ready for connections
Apache error log is:
[client 127.0.0.1] PHP Warning: mysql_pconnect(): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (13) in /usr/lib/zm/html/zm_db.php on line 21
[Mon Sep 12 23:14:15 2005] [error] [client 127.0.0.1] File does not exist: /var/www/html/favicon.ico
[client 127.0.0.1] PHP Notice: import_request_variables(): No prefix specified - possible security hazard in /usr/lib/zm/html/zm.php on line 21
The system error log is:
Sep 12 23:14:15 localhost kernel: audit(1126538055.354:0): avc: denied { write } for pid=2798 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:18:30 localhost kernel: audit(1126538310.932:0): avc: denied { write } for pid=2800 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:18:34 localhost kernel: audit(1126538314.802:0): avc: denied { write } for pid=2802 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:18:36 localhost kernel: audit(1126538316.409:0): avc: denied { write } for pid=2811 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:27:34 localhost su(pam_unix)[7182]: session opened for user apache by root(uid=0)
Sep 12 23:27:35 localhost su(pam_unix)[7182]: session closed for user apache
Sep 12 23:27:52 localhost kernel: audit(1126538871.934:0): avc: denied { write } for pid=2799 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:27:55 localhost kernel: audit(1126538875.090:0): avc: denied { write } for pid=2801 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:27:56 localhost kernel: audit(1126538876.569:0): avc: denied { write } for pid=2803 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:27:57 localhost kernel: audit(1126538877.270:0): avc: denied { write } for pid=2811 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:27:57 localhost kernel: audit(1126538877.851:0): avc: denied { write } for pid=2799 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
Sep 12 23:28:05 localhost kernel: audit(1126538885.459:0): avc: denied { write } for pid=2811 exe=/usr/sbin/httpd name=mysql.sock dev=hda8 ino=19236 scontext=user_u:system_r:httpd_t tcontext=root:object_r:var_lib_t tclass=sock_file
skip-innodb
