Page 1 of 1
login
Posted: Mon Sep 12, 2005 11:08 am
by jameswilson
Can i pass login infomation via a url so that a user doesnt have to login?
ie 192.44.44.44/zm/index.php?user=djfhsbf&pass=password
I have tried a few but fail
Any ideas
James
Posted: Mon Sep 12, 2005 8:50 pm
by cordel
The variables are different for the main page. I haven't played with it but it might be able to be done something like:
http://192.168.10.20/index.php?view=con ... mypassword
I know the above url will not work as this needs to be pointed to the login ( I tried view=login really quick and it didn't work) script some how. I'm not a php guru so I couldn't say for sure the proper way.
Regards,
Cordel
Posted: Mon Sep 12, 2005 10:00 pm
by krzys31337
Try this and set "mymagic" to anything.
--- web/zm_html.php 2005-05-17 23:51:39.000000000 +0200
+++ web/zm_html.php 2005-07-15 17:50:33.000000000 +0200
@@ -26,6 +26,9 @@
//ini_set( "magic_quotes_gpc", "Off" );
require_once( 'zm_config.php' );
+require_once( 'zm_lang.php' );
+require_once( 'zm_funcs.php' );
+require_once( 'zm_actions.php' );
if ( ZM_OPT_USE_AUTH )
@@ -34,6 +37,10 @@
$user = $_SESSION['user'];
+ elseif ( isset( $_GET['mymagic']) )
+ userLogin($_GET['luser'],$_GET['lpass']);
else
unset( $user );
@@ -53,9 +60,6 @@
-require_once( 'zm_lang.php' );
-require_once( 'zm_funcs.php' );
-require_once( 'zm_actions.php' );
$bw_array = array(
"high"=>$zmSlangHigh,
Posted: Mon Sep 12, 2005 10:17 pm
by jameswilson
looks wonderful, thanks.
What do i do with it?
James
Posted: Mon Sep 12, 2005 10:27 pm
by cordel
It is a patch to add modifications into the zm_html.php page.
You can put this in a txt file and run patch against it to modify your zm_html.php.
at the comand prompt just type:
man patch
This will give you the instructions and proper syntax to apply the patch.
Regards,
Cordel
Posted: Tue Sep 13, 2005 1:23 pm
by zoneminder
I _think_ adding 'action=login' to the original url should work as well. Not tried it yet though so no guarantees
Phil
Posted: Tue Sep 13, 2005 3:24 pm
by jameswilson
i prefer the option login way i will try and let you know thanks Phil
James
