Quad/montage
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
jameswilson
Quad/montage
Post by jameswilson »
Could a 9 way or a 4 way cycle be created as well as current options. If you have a lot of monitors say 21 then thats some big monitor for montage lol. Maybe 16 should be a max or option etc
James
zoneminder
Site Admin
Post by zoneminder »
I'm not sure I'm veyr clear about this. Do you mean show 4 or 9 cams for a few seconds and then change to a different 4 or 9 cams?
Phil
jameswilson
yeah phil, is it possible to have say a 4, 9, 12 and 16 way montage and aslo a cycle of the 4, 9, 12, 16. This way if you had 8 cams you would watch cycle 4, 18 cycle 9 etc etc.
Also could these be slectable from the monatge, ie i have opened a 4 way montage and wold like to change to a 9 way or a 4 way cycle, i f the hyperlink or button was already there that would be great.
James
zoneminder
Site Admin
This would be pretty heavy on the conection. I suspect this would be better implemented with a something that can stream a composite image in one. This is under development but not a huge priority at present.
Phil
jameswilson
ok Phil Thanks
James
