For whatever reason I am not having events or imegages being generated as I suspect I should.
I have the camera set up properly, zmc is eatting CPU, so it looks like it's working, but no events or images are showing up... and I can't see anything in the browser.
Not sure what I'm missing.
Logs show nothing happening.
No events/images being generated
sounds like zm cant get any images for whatever reason.
I would start by tring to get live images first. If you cant see live images then zm cant record anthing.
What cameras you using what capture card etc.
Try using tv time or xawtv to check that your hardware is functioning and can work with linux
James
James
- zoneminder
- Site Admin
- Contact:
