Error generating video + Logging issues.
Posted: Wed Sep 28, 2005 3:37 pm
I've been running ZM since 1.19.5, but I have yet to be able to generate video files of events. I have the latest version of ZM (1.21.3) installed on a Debian stable (Sarge) box, running the latest ffmpeg-debs.
zmvideo.log:
Creating video file Event-108336.mpg for event 108336
/usr/bin/ffmpeg -y -hq -intra -r 2.57 -s 352x288 -i %03d-capture.jpg Event-10833 6.mpg > mpeg.log
ffmpeg version 0.4.9-pre1, build 4747, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --build i386-linux --enable-gpl --enable-pp --enable-zlib --en able-vorbis --enable-a52 --enable-dts --disable-debug --prefix=/usr
built on Mar 22 2005 00:10:18, gcc: 3.3.5 (Debian 1:3.3.5-12)
Input #0, image2, from '%03d-capture.jpg':
Duration: 00:10:01.1, start: 0.000000, bitrate: N/A
Stream #0.0: Video: mjpeg, 352x288, 2.57 fps
Output #0, mpeg, to 'Event-108336.mpg':
Stream #0.0: Video: mpeg1video (hq), 352x288, 5.00 fps, q=2-31, 200 kb/s
Stream mapping:
Stream #0.0 -> #0.0
[mpeg1video @ 0x8364eb4]MPEG1/2 doesnt support 5/1 fps
Error while opening codec for output stream #0.0 - maybe incorrect parameters su ch as bit_rate, rate, width or height
Error: 1 at /usr/local/zm/bin/zmvideo.pl line 274.
I hope someone has a revelation from that error, it makes no sense to me
Also, I wish to be able to run all monitors in "Mocord"-mode, but that swamps my logs as there is a lot of activity on the site (ZM goes wild starting/stopping events). Can I configure the syslog-daemon to ignore ZM, or preferably configure ZM to quit logging?
zmvideo.log:
Stream mapping:
Stream #0.0 -> #0.0
