Trouble compiling / linking under debian - kernel: 2.6.8-2-3
tobkron
Post by tobkron »
I need some help building ZoneMinder. Seaching the Forum and reading through FAQ did not help me, solving my problem:
Debian 3.1 : "Linux server 2.6.8-2-386 #1 Thu May 19 17:40:50 JST 2005 i686 GNU/Linux"
I have trouble linking zoneminder "zm-1.21.3":
- configure is fine - except of:
checking for MD5 in -lcrypto... no
configure: WARNING: libcrypto.a is required for authenticated streaming
which I have read, is not a real problem.
- perl ./zmconfig.pl looks good
- make gives me the following error messages:
make all-recursive
make[1]: Entering directory `/usr/src/zm-1.21.3'
Making all in src
make[2]: Entering directory `/usr/src/zm-1.21.3/src'
g++ -g -O2 -L -L/usr/bin/lib -L/usr/lib/mysql -o zmc zmc.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_buffer.o zm_debug.o -L/usr/lib/mysql -lavformat -lavcodec -lpcre -lmysqlclient -ldl -lz -ljpeg
/usr/lib/gcc-lib/i486-linux/3.3.5/../../../libavcodec.a(dtsdec.o)(.text+0x33d): In function `dts_decode_frame':
: undefined reference to `dts_frame'
/usr/lib/gcc-lib/i486-linux/3.3.5/../../../libavcodec.a(dtsdec.o)(.text+0x395): In function `dts_decode_frame':
: undefined reference to `dts_blocks_num'
/usr/lib/gcc-lib/i486-linux/3.3.5/../../../libavcodec.a(dtsdec.o)(.text+0x3bf): In function `dts_decode_frame':
: undefined reference to `dts_block'
/usr/lib/gcc-lib/i486-linux/3.3.5/../../../libavcodec.a(dtsdec.o)(.text+0x3fd): In function `dts_decode_frame':
: undefined reference to `dts_samples'
/usr/lib/gcc-lib/i486-linux/3.3.5/../../../libavcodec.a(dtsdec.o)(.text+0x485): In function `dts_decode_frame':
: undefined reference to `dts_syncinfo'
/usr/lib/gcc-lib/i486-linux/3.3.5/../../../libavcodec.a(dtsdec.o)(.text+0x51e): In function `dts_decode_init':
: undefined reference to `dts_init'
collect2: ld returned 1 exit status
make[2]: *** [zmc] Error 1
make[2]: Leaving directory `/usr/src/zm-1.21.3/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/usr/src/zm-1.21.3'
make: *** [all] Error 2
Thanks a lot for your help
tobkron
zoneminder
Site Admin
Post by zoneminder »
This looks like a problem with the ffmpeg libraries as the function complaining is in one of the ffmpeg libraries. Do you know which version of ffmpeg you have and have you built it with any particular options?
Phil
seb3s
try adding -ldts
Post by seb3s »
I had the same problem with my debian sarge & zm 1.21.3.
I just added -ldts to the following line:
LIBS = -lavformat -lavcodec -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg -ldts
In the 2 files:
- Makefile
- src/Makefile
Have a look at:
http://www.zoneminder.com/forums/viewtopic.php?t=4270
It solved my problem.
Sebastien.
tobkron
Post by tobkron »
Hello Phil,
I did not build ffmpeg, but installed the Debian package:
ffmpeg -v
ffmpeg version 0.4.9-pre1, build 4747, Copyright (c) 2000-2004 Fabrice Bellard
configuration: --build i386-linux --enable-gpl --enable-pp --enable-zlib --enable-vorbis --enable-a52 --enable-dts --disable-debug --prefix=/usr
built on Mar 22 2005 00:10:18, gcc: 3.3.5 (Debian 1:3.3.5-12)
Thank you
tobkron
tobkron
Post by tobkron »
Hello Sebastien,
thanks a lot.
This solved the problem !! - No more complaints by the compiler / linker
Thank you
tobkron
