Page 1 of 1
Newbie - Mostly setup
Posted: Wed Oct 05, 2005 4:50 pm
by Hogface
Ok, I am a newbie.
I don't see anything when I point my browse at my web site.
/http://ghicksfamily.com/index.php
or
/http://ghicksfamily.com/zm.php
my goal is streaming video for security reasons.
*Installed mysql, and all the libmysqlclient, and ffmpeg.
*Mysql permissions seem to all be in order.
*Running on fedora with the 1.2.x version and apache
*USB camera validated with vidcat(w3cam)
Everything compiled with no errors (a few warnings).
The following is running when a ps -aef is done:
apache 13609 1 0 Oct04 ? 00:00:00 /usr/bin/perl -wT /usr/local/bin
/zmdc.pl status
apache 13633 13609 0 Oct04 ? 00:00:00 /usr/bin/perl -wT /usr/local/bin
/zmfilter.pl
apache 13640 13609 0 Oct04 ? 00:00:00 /usr/bin/perl -wT /usr/local/bin
/zmaudit.pl -d 900 -y
apache 13654 13609 0 Oct04 ? 00:00:00 /usr/bin/perl -wT /usr/local/bin
/zmwatch.pl
apache 13659 13609 0 Oct04 ? 00:00:00 /usr/bin/perl -w /usr/local/bin/
zmupdate.pl -c
zmu -d 0 -q -v provides the followings:
Video Capabilities
Type: 513
Can capture
Can capture subareas of the image
Video Channels: 1
Audio Channels: 0
Maximum Width: 352
Maximum Height: 288
Minimum Width: 48
Minimum Height: 48
Window Attributes
X Offset: 0
Y Offset: 0
Width: 352
Height: 288
Picture Attributes
Palette: 4 - 24bit RGB
Colour Depth: 24
Brightness: 32768
Hue: 32768
Colour :32768
Contrast: 32768
Whiteness: 0
Channel 0 Attributes
Channel: 0
Flags: 0
Type: 2 - Camera
Format: 0 - PAL
However - zmc --device 0 returns quickly
and I see the following messages in var/logs/messages:
Oct 5 11:44:21 madie zmc_d0[21425]: INF [Debug Level = 0, Debug Log = <none>]
Oct 5 11:44:21 madie zmc_d0[21425]: ERR [No monitors found]
I'm really not sure where to go from here. Any help would be appreciated.
________
Honda RC163
Posted: Wed Oct 05, 2005 5:41 pm
by jameswilson
http://<ip>/zm/
James
Posted: Wed Oct 05, 2005 6:40 pm
by zoneminder
I assume the / before http is not really there when you try to access the page?
Phil
Posted: Wed Oct 05, 2005 11:46 pm
by Hogface
Yes you are correct, the leading slash is not there.
I do get a ZM symbol with firefox when it hits the page, but its blank.
________
starcraft II replay
Posted: Thu Oct 06, 2005 12:15 am
by cordel
The web page should display no matter what status or errors that the zm binaries through out. Your problem is some where in apache or php. Check your apache logs for any clues and post here. Also may be helpful to know what disrto this is on, apache version, and php version.
Try also putting this in your webs root call the file anything you want just not the same as I use for example for security reasons.
cd /var/www/html (for example)
vi info.php
and put this in it
<?php
phpinfo()
now go to http://<your_host/info.php
If php is working you will see a nice table with lots of information.
Regards,
Cordel
Posted: Thu Oct 06, 2005 1:08 am
by Hogface
Ok cools got lots of stuff here it is:
Apache 2
Fedora 4
PHP Version 5.0.4
System Linux madie.ghicksfamily.com 2.6.13-1.1526_FC4 #1 Wed Sep 28 19:15:10 EDT 2005 i686
Build Date Aug 17 2005 09:54:44
Configure Command './configure' '--build=i386-redhat-linux' '--host=i386-redhat-linux' '--target=i386-redhat-linux-gnu' '--program-prefix=' '--prefix=/usr' '--exec-prefix=/usr' '--bindir=/usr/bin' '--sbindir=/usr/sbin' '--sysconfdir=/etc' '--datadir=/usr/share' '--includedir=/usr/include' '--libdir=/usr/lib' '--libexecdir=/usr/libexec' '--localstatedir=/var' '--sharedstatedir=/usr/com' '--mandir=/usr/share/man' '--infodir=/usr/share/info' '--cache-file=../config.cache' '--with-libdir=lib' '--with-config-file-path=/etc' '--with-config-file-scan-dir=/etc/php.d' '--disable-debug' '--with-pic' '--disable-rpath' '--with-bz2' '--with-curl' '--with-exec-dir=/usr/bin' '--with-freetype-dir=/usr' '--with-png-dir=/usr' '--enable-gd-native-ttf' '--without-gdbm' '--with-gettext' '--with-gmp' '--with-iconv' '--with-jpeg-dir=/usr' '--with-openssl' '--with-png' '--with-pspell' '--with-expat-dir=/usr' '--with-pcre-regex=/usr' '--with-zlib' '--with-layout=GNU' '--enable-exif' '--enable-ftp' '--enable-magic-quotes' '--enable-sockets' '--enable-sysvsem' '--enable-sysvshm' '--enable-sysvmsg' '--enable-track-vars' '--enable-trans-sid' '--enable-yp' '--enable-wddx' '--with-pear=/usr/share/pear' '--with-kerberos' '--enable-ucd-snmp-hack' '--with-unixODBC=shared,/usr' '--enable-memory-limit' '--enable-shmop' '--enable-calendar' '--enable-dbx' '--enable-dio' '--with-mime-magic=/etc/httpd/conf/magic' '--without-sqlite' '--with-libxml-dir=/usr' '--with-xml' '--with-apxs2=/usr/sbin/apxs' '--without-mysql' '--without-gd' '--without-odbc' '--disable-dom' '--disable-dba'
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php.ini
Scan this dir for additional .ini files /etc/php.d
additional .ini files parsed /etc/php.d/ldap.ini
PHP API 20031224
PHP Extension 20041030
Zend Extension 220040412
Debug Build no
Thread Safety disabled
IPv6 Support enabled
Registered PHP Streams php, file, http, ftp, compress.bzip2, compress.zlib, https, ftps
Registered Stream Socket Transports tcp, udp, unix, udg, ssl, sslv3, sslv2, tls
Zend logo This program makes use of the Zend Scripting Language Engine:
Zend Engine v2.0.4-dev, Copyright (c) 1998-2004 Zend Technologies
PHP Credits
Configuration
PHP Core
Directive Local Value Master Value
allow_call_time_pass_reference Off Off
allow_url_fopen On On
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_globals_jit On On
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors Off Off
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 2047 2047
expose_php On On
extension_dir /usr/lib/php/modules /usr/lib/php/modules
file_uploads On On
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path .:/usr/share/pear .:/usr/share/pear
log_errors On On
log_errors_max_len 1024 1024
magic_quotes_gpc Off Off
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
mail.force_extra_parameters no value no value
max_execution_time 30 30
max_input_time 60 60
memory_limit 8M 8M
open_basedir no value no value
output_buffering 4096 4096
output_handler no value no value
post_max_size 8M 8M
precision 14 14
register_argc_argv On On
register_globals Off Off
register_long_arrays Off Off
report_memleaks On On
report_zend_debug On On
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
zend.ze1_compatibility_mode Off Off
apache2handler
Apache Version Apache/2.0.54 (Fedora)
Apache API Version 20020903
Server Administrator root@localhost
Hostname:Port madie.ghicksfamily.com:0
User/Group apache(48)/48
Max Requests Per Child: 4000 - Keep Alive: off - Max Per Connection: 100
Timeouts Connection: 120 - Keep-Alive: 15
Virtual Server No
Server Root /etc/httpd
Loaded Modules core prefork http_core mod_so mod_access mod_auth mod_auth_anon mod_auth_dbm mod_auth_digest util_ldap mod_auth_ldap mod_include mod_log_config mod_logio mod_env mod_mime_magic mod_cern_meta mod_expires mod_deflate mod_headers mod_usertrack mod_setenvif mod_mime mod_dav mod_status mod_autoindex mod_asis mod_info mod_dav_fs mod_vhost_alias mod_negotiation mod_dir mod_actions mod_speling mod_userdir mod_alias mod_rewrite mod_proxy proxy_ftp proxy_http proxy_connect mod_cache mod_suexec mod_disk_cache mod_file_cache mod_mem_cache mod_cgi mod_perl mod_php5 mod_python mod_ssl
engine 1 1
last_modified 0 0
xbithack 0 0
Apache Environment
Variable Value
HTTP_HOST www.ghicksfamily.com
HTTP_USER_AGENT Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.12) Gecko/20050915 Firefox/1.0.7
HTTP_ACCEPT text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
HTTP_ACCEPT_LANGUAGE en-us,en;q=0.5
HTTP_ACCEPT_ENCODING gzip,deflate
HTTP_ACCEPT_CHARSET ISO-8859-1,utf-8;q=0.7,*;q=0.7
HTTP_KEEP_ALIVE 300
HTTP_CONNECTION keep-alive
PATH /sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
SERVER_SIGNATURE <address>Apache/2.0.54 (Fedora) Server at www.ghicksfamily.com Port 80</address>
SERVER_SOFTWARE Apache/2.0.54 (Fedora)
SERVER_NAME www.ghicksfamily.com
SERVER_ADDR 200.200.200.215
SERVER_PORT 80
REMOTE_ADDR 200.200.200.254
DOCUMENT_ROOT /var/www/html
SERVER_ADMIN root@localhost
SCRIPT_FILENAME /var/www/html/info.php
REMOTE_PORT 1459
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /info.php
SCRIPT_NAME /info.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /info.php HTTP/1.1
Host www.ghicksfamily.com
User-Agent Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.12) Gecko/20050915 Firefox/1.0.7
Accept text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
Accept-Language en-us,en;q=0.5
Accept-Encoding gzip,deflate
Accept-Charset ISO-8859-1,utf-8;q=0.7,*;q=0.7
Keep-Alive 300
Connection keep-alive
HTTP Response Headers
X-Powered-By PHP/5.0.4
Connection close
Transfer-Encoding chunked
Content-Type text/html; charset=UTF-8
bz2
BZip2 Support Enabled
BZip2 Version 1.0.2, 30-Dec-2001
calendar
Calendar support enabled
ctype
ctype functions enabled
curl
CURL support enabled
CURL Information libcurl/7.13.1 OpenSSL/0.9.7f zlib/1.2.2.2 libidn/0.5.15
dbx
dbx support enabled
dbx version 1.1.0
supported databases MySQL ODBC PostgreSQL Microsoft SQL Server FrontBase Oracle 8 (oci8) Sybase-CT SQLite
dbx.colnames_case lowercase lowercase
dio
dio support enabled
exif
EXIF Support enabled
EXIF Version 1.4 $Id: exif.c,v 1.162.2.8 2005/03/17 17:20:35 iliaa Exp $
Supported EXIF Version 0220
Supported filetypes JPEG,TIFF
ftp
FTP support enabled
gettext
GetText Support enabled
gmp
gmp support enabled
iconv
iconv support enabled
iconv implementation glibc
iconv library version 2.3.5
iconv.input_encoding ISO-8859-1 ISO-8859-1
iconv.internal_encoding ISO-8859-1 ISO-8859-1
iconv.output_encoding ISO-8859-1 ISO-8859-1
ldap
LDAP Support enabled
RCS Version $Id: ldap.c,v 1.154.2.2 2005/01/19 00:27:42 sniper Exp $
Total Links 0/unlimited
API Version 3001
Vendor Name OpenLDAP
Vendor Version 20223
libxml
libXML support active
libXML Version 2.6.20
libXML streams enabled
mime_magic
mime_magic support enabled
mime_magic.debug Off Off
mime_magic.magicfile /etc/httpd/conf/magic /etc/httpd/conf/magic
openssl
OpenSSL support enabled
OpenSSL Version OpenSSL 0.9.7f 22 Mar 2005
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 5.0 13-Sep-2004
posix
Revision $Revision: 1.60.2.2 $
pspell
PSpell Support enabled
session
Session Support enabled
Registered save handlers files user
Registered serializer handlers php php_binary wddx
session.auto_start Off Off
session.bug_compat_42 Off Off
session.bug_compat_warn On On
session.cache_expire 180 180
session.cache_limiter nocache nocache
session.cookie_domain no value no value
session.cookie_lifetime 0 0
session.cookie_path / /
session.cookie_secure Off Off
session.entropy_file no value no value
session.entropy_length 0 0
session.gc_divisor 1000 1000
session.gc_maxlifetime 1440 1440
session.gc_probability 1 1
session.hash_bits_per_character 5 5
session.hash_function 0 0
session.name PHPSESSID PHPSESSID
session.referer_check no value no value
session.save_handler files files
session.save_path /var/lib/php/session /var/lib/php/session
session.serialize_handler php php
session.use_cookies On On
session.use_only_cookies Off Off
session.use_trans_sid 0 0
shmop
shmop support enabled
SimpleXML
Simplexml support enabled
Revision $Revision: 1.139.2.4 $
Schema support enabled
sockets
Sockets Support enabled
SPL
SPL support enabled
Interfaces RecursiveIterator, SeekableIterator
Classes ArrayObject, ArrayIterator, CachingIterator, CachingRecursiveIterator, DirectoryIterator, FilterIterator, LimitIterator, ParentIterator, RecursiveDirectoryIterator, RecursiveIteratorIterator, SimpleXMLIterator
standard
Regex Library Bundled library enabled
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
date.default_latitude 31.7667 31.7667
date.default_longitude 35.2333 35.2333
date.sunrise_zenith 90.83 90.83
date.sunset_zenith 90.83 90.83
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,input=src,form=fakeentry a=href,area=href,frame=src,input=src,form=fakeentry
user_agent no value no value
sysvmsg
sysvmsg support enabled
Revision $Revision: 1.16.2.3 $
tokenizer
Tokenizer Support enabled
wddx
WDDX Support enabled
WDDX Session Serializer enabled
xml
XML Support active
XML Namespace Support active
libxml2 Version 2.6.20
yp
YP Support enabled
zlib
ZLib Support enabled
Compiled Version 1.2.2.2
Linked Version 1.2.2.2
zlib.output_compression Off Off
zlib.output_compression_level -1 -1
zlib.output_handler no value no value
Additional Modules
Module Name
sysvsem
sysvshm
Environment
Variable Value
LANG C
TERM xterm
PWD /
SHLVL 1
_ /usr/sbin/httpd
PHP Variables
Variable Value
_SERVER["HTTP_HOST"] www.ghicksfamily.com
_SERVER["HTTP_USER_AGENT"] Mozilla/5.0 (Windows; U; Windows NT 5.1; en-US; rv:1.7.12) Gecko/20050915 Firefox/1.0.7
_SERVER["HTTP_ACCEPT"] text/xml,application/xml,application/xhtml+xml,text/html;q=0.9,text/plain;q=0.8,image/png,*/*;q=0.5
_SERVER["HTTP_ACCEPT_LANGUAGE"] en-us,en;q=0.5
_SERVER["HTTP_ACCEPT_ENCODING"] gzip,deflate
_SERVER["HTTP_ACCEPT_CHARSET"] ISO-8859-1,utf-8;q=0.7,*;q=0.7
_SERVER["HTTP_KEEP_ALIVE"] 300
_SERVER["HTTP_CONNECTION"] keep-alive
_SERVER["PATH"] /sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
_SERVER["SERVER_SIGNATURE"] <address>Apache/2.0.54 (Fedora) Server at www.ghicksfamily.com Port 80</address>
_SERVER["SERVER_SOFTWARE"] Apache/2.0.54 (Fedora)
_SERVER["SERVER_NAME"] www.ghicksfamily.com
_SERVER["SERVER_ADDR"] 200.200.200.215
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] 200.200.200.254
_SERVER["DOCUMENT_ROOT"] /var/www/html
_SERVER["SERVER_ADMIN"] root@localhost
_SERVER["SCRIPT_FILENAME"] /var/www/html/info.php
_SERVER["REMOTE_PORT"] 1459
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /info.php
_SERVER["SCRIPT_NAME"] /info.php
_SERVER["PHP_SELF"] /info.php
_SERVER["argv"]
Array
_SERVER["argc"] 0
_ENV["LANG"] C
_ENV["TERM"] xterm
_ENV["PATH"] /sbin:/usr/sbin:/bin:/usr/bin:/usr/X11R6/bin
_ENV["PWD"] /
_ENV["SHLVL"] 1
_ENV["_"] /usr/sbin/httpd
PHP License
This program is free software; you can redistribute it and/or modify it under the terms of the PHP License as published by the PHP Group and included in the distribution in the file: LICENSE
This program is distributed in the hope that it will be useful, but WITHOUT ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
If you did not receive a copy of the PHP license, or have any questions about PHP licensing, please contact license@php.net.
________
ecig forum
Posted: Thu Oct 06, 2005 2:38 am
by Hogface
Ok,
The suggestion for look into logs was helpful.
I am getting an error message:
[client 67.141.168.157] PHP Fatal error: Call to undefined function mysql_pconnect() in /var/www/html/zm_db.php on line 21
I double checked and install via (yum) php-mysql.i386.
Still getting the error.
________
Mercedes-Benz W120/121
Posted: Thu Oct 06, 2005 3:19 am
by cordel
In the php.ini you must enable zend.ze1_compatibility_mode
so that you have:
zend.ze1_compatibility_mode = On
Also make sure you have SELinux disabled or in passive mode (Passive mode generates alot of log info so best to just disable it).
Regards,
Cordel
Posted: Thu Oct 06, 2005 3:31 am
by Hogface
Thank you for the help.
I enabled and restart httpd. Is there a php daemon/service?
Where to I change the SEL setting?
I also verified that mysql is up, and userid/password/and tables were all as should be (including permissions).
________
starcraft II replay
Posted: Thu Oct 06, 2005 3:34 am
by Hogface
Hold the phone ! the site now provides me a page! Yee Haw! (That how we talk here in Arkansas!
Let me experiment for a bit now!
________
CT50 Motra
Posted: Thu Oct 06, 2005 3:44 am
by cordel
Just make sure you disable SELinux, save that config, and reboot the machine. After that you should not have to many issues. You may need to go back into the zm source directory and redo the make and make install, I don't remember though what all SELinux did so I'm not sure. So if you find that things are not working right and someone is sure that you have everything setup right. Just redo those two things (you can do it anyway to be sure if you would like :wink:
Regards,
Cordel
Posted: Thu Oct 06, 2005 3:49 am
by Hogface
Will do, but how do you disable it?
Also I can't get my dev to not be "red", but at least
zmc --device 0 now pauses for 1sec before returning, so I think
I'm making progress.
I can't tell you how much I really appreciate your help!
________
Ford Motor Company of Canada
Posted: Thu Oct 06, 2005 4:18 am
by cordel
Go to the menu bar-> Applications->System settings ->Security Level
Click on the SELinux tab and uncheck Enabled.
Regards,
Cordel
