Page 1 of 2
Errors in messages.log
Posted: Thu Oct 06, 2005 4:58 pm
by Hogface
Thanks to lots of help, I have made progress, but now I get:
I have followed the docs and set strict, but still get this:
ERR [Failed to set picture attributes: Invalid argument]
I have reduced/changed every attribute that I can and yet I still get the message.
I also get
zmu[3013]: ERR [Shared memory not initialised by capture daemon]
I have searched the forum and help, and can't find anything.
Thank you.
________
vaporizer affiliate program
Posted: Thu Oct 06, 2005 5:30 pm
by jameswilson
what res are your cameras setup to. If you search for your error you will find plenty of things but the best howti is in the faq. Check you are on med res ie 320x240 and that you have restarted zm
James
Posted: Thu Oct 06, 2005 5:32 pm
by jameswilson
and i assume yoir having an issue capturing images
Posted: Fri Oct 07, 2005 12:56 am
by Hogface
I can't see any video when I try to view it.
In /var/log I see the following:
________
buy vaporgenie
Posted: Fri Oct 07, 2005 2:49 am
by Hogface
Each time I try and do anything I get this in /var/log:
Oct 6 21:45:27 madie zmc_d0[3538]: INF [Debug Level = 0, Debug Log = <none>]
Oct 6 21:45:28 madie zmc_d0[3538]: ERR [Failed to set picture attributes: Invalid argument]
Oct 6 21:45:29 madie zmu[3549]: ERR [Shared memory not initialised by capture daemon]
Oct 6 21:45:40 madie zmu[3554]: ERR [Shared memory not initialised by capture daemon]
Also the /dev/video(0) is red.
(I validated the camera works with vidcat/w3cam)
________
universal health warehouse
Posted: Fri Oct 07, 2005 4:06 am
by cordel
What settings do you have for the camera in zm?
Does those setting mach what the camera can do (size, color palet, etc...)?
Posted: Fri Oct 07, 2005 10:12 pm
by Hogface
Monitor - USB
Monitor Source Timestamp Buffers Misc Control X10
Parameter Value
Name USB
Function Monitor
Section length 100
Frame Skip 1
Run Mode Continous
Triggers X10
Source Type
Parameter Value
Device Number (/dev/video?) 0
Device Channel 1
Device Format (0=PAL,1=NTSC etc) 0
Capture Palette RGB24
Capture Width (pixels) 176 also tried 352
Capture Height (pixels) 144 also tried 288
Orientation
________
medical marijuana
Posted: Fri Oct 07, 2005 10:22 pm
by jameswilson
i dont know much about usb webams but im sure i read somewhere that the res you catpure at is critical. If it were me thats what id start with on google or your prefered search eng
James
*edit dont matter for now but why a section length of 100?
Posted: Fri Oct 07, 2005 10:43 pm
by jameswilson
can you get your webcam working in tvtime?
Posted: Fri Oct 07, 2005 10:45 pm
by Hogface
The camera is a DLink 300, (I think)
I have found the identifier inside as a cv-1620.
The camera works with w3cam/vidcat and can capture a still
________
medical marijuana news
Posted: Fri Oct 07, 2005 10:51 pm
by jameswilson
at what res and colour pallete?
Posted: Fri Oct 07, 2005 11:16 pm
by Hogface
See above message for more details:
I have tried all the choices for palettes and when lower on resolution.
The above message has all the settings.
________
Mirada
Posted: Fri Oct 07, 2005 11:22 pm
by jameswilson
no i meant when you got an image from vidcat what was its image size
Posted: Sat Oct 08, 2005 11:45 am
by Hogface
640x480,
I've tried those settings also.
________
Model 48
Posted: Sat Oct 08, 2005 11:59 am
by jameswilson
mmmm dont know thwn if you have had it working in linux it obviuosly has drivers and modules it needs ok. Im afraid i dont know
James
