Page 1 of 1
Remote view by Internet Explorer
Posted: Fri Oct 07, 2005 7:44 am
by bujia
Hi!
My question:
If I have a ZM system correctly installed and running, can I view ZM console and so cams by Internet Explorer on a PC connectec via VPN with ZM Host? I would view my cam by remote with Windows machine, and browser Internet Explorer, I need only connections and no others software?
Thanks in advance!
Alessandro
Posted: Fri Oct 07, 2005 10:11 am
by cordel
Yes you could see the remote server if things are setup correctly.
Here is an example for you.
http://www.ctu-web.com:8080
both the user and pass are: guest
Regards,
Cordel
