Okay... I realize that this isn't really the original intended use for ZM, but I'm already using ZM to monitor some webcams, and I want to see if I can get it to do this extra bit for me.
I want to collect a series of weather images from weather.com so that I can go back and see how the images change over several days, between seasons, etc. I figured ZM would be good for this, but the requirements are a little different from my webcam settings:
1 - I don't want to be slamming weather.com with a request every second or so. I'd like to get it so that it checks once per hour or so. However, unless this is done with the "Maximum FPS" setting, I have no idea where to change the rate at which I poll the remote site.
2 - I'd also like to only save an image if it has *changed*. This is probably a job for Modect, but I don't want ZM to highlight the changed portions of the weather picture. I've found the place in ZM where I can change the *color* of the alarmed areas of zone, but I don't see where to turn it off completely.
3 - For the time being, I don't want to generate any video from these images... I just want to see the stills. However, whenever I click on this monitor's name in the main ZM window, the popup window defaults to the "Stream" mode... and I always have to click on "Stills" to get what I want. Is there a way to get it to default to Stills?
Any help would be appreciated.
- Joe
Best settings for archiving images from a remote website?
sounds interesting
1 your right just set your fps at something like 0.001 or whatever it works out to be
2 options turn offf the lower ticks ie zm_create_anaylis_images not sure how modect would do this but worth a go
3 it shouldnt matter streaming as the image wont be changing or am i missing something
Good luck
James
Good luck
James
- zoneminder
- Site Admin
- Contact:
Modect works just fine without analysis images. It's just a bit of extra eye candy really so you can see where ZM thinks the interesting parts are.
You can change the streaming behaviour either by changing Options->Tools->ZM_CAN_STREAM to no (if you never want streaming) or edit zm_html_view_watchfeed.php and change the default streaming mode near the top of that file.
Phil
Phil
Well, ZM doesn't seems to treat anything less than 0.01 as 0.00.jameswilson wrote:sounds interesting
Now, I've got a new problem.
When ZM sees the image change, it treats it as an alarm event and it then records a few dozen frames... which all look the same.
What I want is for each alert event to capture *one* frame, and then revert back to its normal "watching for image changes" again.
Is there a way to get ZM to behave like this?
- Joe
You can play with both the buffers setting (decreasing the images capture for pre and post) and set the referance image to be updated at a higher percentage.
3939663646337
It's better to keep your mouth shut and appear stupid than open it and remove all doubt.
-Mark Twain
