Originally ran with a single chip 4 input card (77) and all is wonderful in zm world.
Testing a 206m at full ress added this to the box as input 5 set max fps on cam 3 and low jpg compression
It works wonderfully
Downside is my original 4 worked for a bit (10 mins or so) and now are all red in console.
Log
- Oct 8 13:22:37 localhost zmc_d0[7112]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:22:38 localhost zmc_d0[7112]: INF [Starting Capture]
Oct 8 13:22:38 localhost zmc_d0[7112]: INF [Got TERM signal, exiting]
Oct 8 13:22:38 localhost zmc_d0[7112]: ERR [Sync failure for frame 2 buffer 2(1): Interrupted system call]
Oct 8 13:22:49 localhost zmc_d0[7143]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:22:49 localhost zmc_d0[7143]: INF [Starting Capture]
Oct 8 13:22:50 localhost zmc_d0[7143]: INF [Got TERM signal, exiting]
Oct 8 13:22:50 localhost zmc_d0[7143]: ERR [Sync failure for frame 2 buffer 2(1): Interrupted system call]
Oct 8 13:23:00 localhost zmc_d0[7149]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:23:01 localhost zmc_m6[6845]: INF [New: 1000 - Capturing at 2.99 fps]
Oct 8 13:23:01 localhost zmc_d0[7149]: INF [Starting Capture]
Oct 8 13:23:01 localhost zmc_d0[7149]: INF [Got TERM signal, exiting]
Oct 8 13:23:01 localhost zmc_d0[7149]: ERR [Sync failure for frame 5 buffer 5(1): Interrupted system call]
Oct 8 13:23:02 localhost zma_m6[6857]: INF [New: 1000 - Processing at 2.98 fps]
Oct 8 13:23:12 localhost zmc_d0[7155]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:23:13 localhost zmc_d0[7155]: INF [Starting Capture]
Oct 8 13:23:13 localhost zmc_d0[7155]: INF [Got TERM signal, exiting]
Oct 8 13:23:13 localhost zmc_d0[7155]: ERR [Sync failure for frame 1 buffer 1(1): Interrupted system call]
Oct 8 13:23:24 localhost zmc_d0[7161]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:23:24 localhost zmc_d0[7161]: INF [Starting Capture]
Oct 8 13:23:25 localhost zmc_d0[7161]: INF [Got TERM signal, exiting]
Oct 8 13:23:25 localhost zmc_d0[7161]: ERR [Sync failure for frame 2 buffer 2(1): Interrupted system call]
Oct 8 13:23:36 localhost zmc_d0[7168]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:23:36 localhost zmc_d0[7168]: INF [Starting Capture]
Oct 8 13:23:36 localhost zmc_d0[7168]: INF [Got TERM signal, exiting]
Oct 8 13:23:36 localhost zmc_d0[7168]: ERR [Sync failure for frame 0 buffer 0(1): Interrupted system call]
Oct 8 13:23:47 localhost zmc_d0[7174]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:23:47 localhost zmc_d0[7174]: INF [Starting Capture]
Oct 8 13:23:48 localhost zmc_d0[7174]: INF [Got TERM signal, exiting]
Oct 8 13:23:48 localhost zmc_d0[7174]: ERR [Sync failure for frame 1 buffer 1(1): Interrupted system call]
Oct 8 13:23:58 localhost zmc_d0[7180]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:23:59 localhost zmc_d0[7180]: INF [Starting Capture]
Oct 8 13:23:59 localhost zmc_d0[7180]: INF [Got TERM signal, exiting]
Oct 8 13:23:59 localhost zmc_d0[7180]: ERR [Sync failure for frame 0 buffer 0(1): Interrupted system call]
Oct 8 13:24:10 localhost zmc_d0[7186]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:24:10 localhost zmc_d0[7186]: INF [Starting Capture]
Oct 8 13:24:10 localhost zmc_d0[7186]: INF [Got TERM signal, exiting]
Oct 8 13:24:10 localhost zmc_d0[7186]: ERR [Sync failure for frame 0 buffer 0(1): Interrupted system call]
Oct 8 13:24:21 localhost zmc_d0[7192]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:24:22 localhost zmc_d0[7192]: INF [Starting Capture]
Oct 8 13:24:22 localhost zmc_d0[7192]: INF [Got TERM signal, exiting]
Oct 8 13:24:22 localhost zmc_d0[7192]: ERR [Sync failure for frame 2 buffer 2(1): Interrupted system call]
Oct 8 13:24:33 localhost zmc_d0[7199]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:24:33 localhost zmc_d0[7199]: INF [Starting Capture]
Oct 8 13:24:33 localhost zma_m3[3975]: INF [Cam_2: 4403 - Gone into alert state]
Oct 8 13:24:34 localhost zmc_d0[7199]: INF [Got TERM signal, exiting]
Oct 8 13:24:34 localhost zmc_d0[7199]: ERR [Sync failure for frame 5 buffer 5(1): Interrupted system call]
Oct 8 13:24:44 localhost zmc_d0[7205]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:24:45 localhost zmc_d0[7205]: INF [Starting Capture]
Oct 8 13:24:46 localhost zmc_d0[7205]: INF [Got TERM signal, exiting]
Oct 8 13:24:46 localhost zmc_d0[7205]: ERR [Sync failure for frame 4 buffer 4(1): Interrupted system call]
Oct 8 13:24:56 localhost zmc_d0[7211]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:24:57 localhost zmc_d0[7211]: INF [Starting Capture]
Oct 8 13:24:57 localhost zma_m3[3975]: INF [Cam_2: 4406 - Gone back into alarm state]
Oct 8 13:24:57 localhost zmc_d0[7211]: INF [Got TERM signal, exiting]
Oct 8 13:24:57 localhost zmc_d0[7211]: ERR [Sync failure for frame 2 buffer 2(1): Interrupted system call]
Oct 8 13:25:08 localhost zmc_d0[7217]: INF [Debug Level = 0, Debug Log = <none>]
Oct 8 13:25:08 localhost zmc_d0[7217]: INF [Starting Capture]
Oct 8 13:25:09 localhost zmc_d0[7217]: INF [Got TERM signal, exiting]
Oct 8 13:25:09 localhost zmc_d0[7217]: ERR [Sync failure for frame 0 buffer 0(1): Interrupted system call]
My megapixel still works even though other dont. Any ideas.
James
