Yellow (aged) video
Hogface
Yellow (aged) video
Post by Hogface »
I have installed a camera.
I get a yellow Picture.
In the settings, the hue and Color have large numbers.
When I change them to 0 each, my picture goes good, then reset back the bad values.
How can I get the values to stick?
________
Suzuki RE5 specifications
Hogface
Post by Hogface »
I figured it out so far.
I am experience issues with resource on the USB ports.
One minute one camera work, then the next will work.
Getting errors in message log regarding uhci issues.
________
hotels in mexico city
zoneminder
Site Admin
Post by zoneminder »
I suspect this is because your two cameras are competing for the USB bandwidth, assuming they are on the same bus. You usally have to indicate when the driver is loaded that you have more than one camera on a bus and then they share a bit better. Which driver are you using?
Phil
