Can't access ZM from any PC other than "server" co
joemapango
Post by joemapango »
Hello All. I loaded up the live CD and ZM worked flawlessly. I purchased a video input card from one of the ad's on the website, and that worked first time also. All functions are working from the ZM "server" or localhost.
When I try to access ZM from another PC on my network I get an error. I can access the apache page, but when I go to http://my_zm_hostname_or_ip/zm I get an error,
The connection was refused when attempting to contact 127.0.0.1
My question is this: How can I setup my ZM on a PC other than localhost?
I have the following in my host file
127.0.0.1 localhost localhost.local.domain
10.12.0.132 zm zm.mydomain.com
Thanks for any advice you can give!
cordel
Post by cordel »
Have you check your apache logs?
If so was there any errors?
Have you checked and made sure that if an virtual host was setup that it don't think it's at ip127.0.0.1?
Where did you set up this host file, on a workstation?
Regards,
Cordel
