X10 Output Alarm Smarts.
Anything you want added or changed in future versions of ZoneMinder? Post here and there's a chance it will get in! Search to make sure it hasn't already been requested.
p_thrill
Post by p_thrill »
Version: ZM v1.21.3
X10 Enabled; Run Mode: Continuous; X10 Output Alarm String: 3+600
Problem: Infinite loop of lights on/off (motion detected; lights on; wait 10 min; lights off; creates alarm; lights on, etc...)
Goal: Suspend alarms with (zmu -m 3 -u); turn off the lights; Resume alarms with (zmu -m 3 -r)
I've tried to modifiy the zmx10.pl script to include the zmu command, but my knowledge of perl is very limited. Has anyone found a solution/work around to this problem? Is this something that can be considered for future releases?
jameswilson
Post by jameswilson »
just an idea, when the lights come back on the change should be accross the whole image, could you alter the zone to ignore changes bigger than 90% etc
James
James Wilson
