Hi. My name is Favio, I am from Argentina.
I tried to install the zoneminder distro based on his CTU core (fedora), buy I have aproblem with the cambozola distribution, because I just see an black image with the hour and the tima. Please, if someone could help me to finish my installation, I will be very interesting on it. thanks a lot. And the second question, zoneminder it´s only run in Linux ? Thanks ... Sorry for my english and for my incomprension. And if some person like to contact me, please, feel free to do it. Thanks !!!
Hi from Argentina
hi from England.
I dont think you have a cabozola problem more likely a video capture problem. We will need to know to start with
Machine specs, camera type, capture res, fps etc, and as much error logs as you can find , relevant ones mind.
James
James
James Wilson
Hi Favio,
Yes, ZoneMinder is only supported in linux.
If you see the clock in cambozola then the java app is working fine. We will need a bit more info though to be able to help you.
What is your machine specs?
What capture card or method of capture?
What if any errors are in the ZM or system logs?
If you would like you may PM or email me login info and I can ssh in and help you out.
I can also give you a phone call and walk you trough it as well.
Regards,
Cordel
Regards,
Cordel
