hi trying to update my livecd hardrive installed version 1.21.3
i get to the ./configure --with-webdir=<your web directory> --with-cgidir=<your cgi directory>
and it crashs
where would the previous config.log hide
here is the config.log created when i tried to update
This file contains any messages produced by compilers while
running configure, to aid debugging if configure makes a mistake.
It was created by configure, which was
generated by GNU Autoconf 2.59. Invocation command line was
$ ./configure --with-webdir=/var/www/html/zm --with-cgidir=/var/www/cgi-bin
## Platform. ##
hostname = zm.local.domain
uname -m = i686
uname -r = 2.6.7-2.tmb.6mdk
uname -s = Linux
uname -v = #1 Tue Aug 31 18:04:06 CEST 2004
/usr/bin/uname -p = unknown
/bin/uname -X = unknown
/bin/arch = i686
/usr/bin/arch -k = unknown
/usr/convex/getsysinfo = unknown
hostinfo = unknown
/bin/machine = unknown
/usr/bin/oslevel = unknown
/bin/universe = unknown
PATH: /sbin
PATH: /usr/sbin
PATH: /bin
PATH: /usr/bin
PATH: /usr/X11R6/bin
PATH: /usr/local/bin
PATH: /root/bin
PATH: /usr/java/j2re1.4.2/bin
PATH: /usr/games
PATH: /usr/local/Acrobat5/bin/
## Core tests. ##
configure:1363: checking for a BSD-compatible install
configure:1418: result: /usr/bin/install -c
configure:1429: checking whether build environment is sane
configure:1472: result: yes
configure:1537: checking for gawk
configure:1553: found /bin/gawk
configure:1563: result: gawk
configure:1573: checking whether make sets $(MAKE)
configure:1593: result: yes
configure:1779: WARNING: You can call configure with the --with-mysql option.
This tells configure where to find the MySql C library and headers if configure cannot
locate them automatically..
e.g. --with-mysql=/usr/local or --with-mysql=/usr
configure:1808: WARNING: You can call configure with the --with-ffmpeg option.
This tells configure where to find the ffmpeg root directory within which are the libavcodec
and libavformat files that can be used to build true MPEG streaming into ZoneMinder. Ensure that
your copy of ffmpeg has installed libraries as well as binaries (use 'make installlib'). If you
are using a local install of ffmpeg you may have to remove or rename a previous real installation
as the headers and libraries from that will probably be picked up before your local copy.
e.g. --with-ffmpeg=/usr/local
configure:1839: WARNING: You can call configure with the --with-lame option.
This tells configure where to find the Lame library which can be used by the ffmpeg libraries
to generate IE compatible MPEG audio streams. This option is only necessary if you have built
the ffmpeg package itself with the --enable-mp3lame option and if the normal link cannot
find the library. Using mp3lame is not necessary or of any benefit to ZoneMinder per se.
e.g. --with-lame=/use/local/lib
configure:1902: WARNING: You can call configure with the --with-webuser option.
This tells configure what the user name of the web user is if it is not the default of 'apache'.
e.g. --with-webuser=apache or --with-webuser=web
configure:1920: WARNING: You can call configure with the --with-webgroup option.
This tells configure what the group name of the web group is if it is not the default of 'apache'.
e.g. --with-webgroup=apache or --with-webgroup=web
configure:1974: checking for gcc
configure:2003: result: no
configure:2054: checking for cc
configure:2083: result: no
configure:2096: checking for cc
configure:2142: result: no
configure:2195: checking for cl
configure:2224: result: no
configure:2238: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
## Cache variables. ##
ac_cv_env_CC_set=
ac_cv_env_CC_value=
ac_cv_env_CFLAGS_set=
ac_cv_env_CFLAGS_value=
ac_cv_env_CPPFLAGS_set=
ac_cv_env_CPPFLAGS_value=
ac_cv_env_CPP_set=
ac_cv_env_CPP_value=
ac_cv_env_CXXCPP_set=
ac_cv_env_CXXCPP_value=
ac_cv_env_CXXFLAGS_set=
ac_cv_env_CXXFLAGS_value=
ac_cv_env_CXX_set=
ac_cv_env_CXX_value=
ac_cv_env_LDFLAGS_set=
ac_cv_env_LDFLAGS_value=
ac_cv_env_build_alias_set=
ac_cv_env_build_alias_value=
ac_cv_env_host_alias_set=
ac_cv_env_host_alias_value=
ac_cv_env_target_alias_set=
ac_cv_env_target_alias_value=
ac_cv_path_install='/usr/bin/install -c'
ac_cv_prog_AWK=gawk
ac_cv_prog_make_make_set=yes
## Output variables. ##
ACLOCAL='${SHELL} /home/marty/zm-1.21.4/missing --run aclocal-1.9'
AMDEPBACKSLASH=''
AMDEP_FALSE=''
AMDEP_TRUE=''
AMTAR='${SHELL} /home/marty/zm-1.21.4/missing --run tar'
AUTOCONF='${SHELL} /home/marty/zm-1.21.4/missing --run autoconf'
AUTOHEADER='${SHELL} /home/marty/zm-1.21.4/missing --run autoheader'
AUTOMAKE='${SHELL} /home/marty/zm-1.21.4/missing --run automake-1.9'
AWK='gawk'
CC=''
CCDEPMODE=''
CFLAGS=''
CGI_PREFIX='/var/www/cgi-bin'
CPP=''
CPPFLAGS=''
CXX=''
CXXCPP=''
CXXDEPMODE=''
CXXFLAGS=''
CYGPATH_W='echo'
DEFS=''
DEPDIR=''
ECHO_C=''
ECHO_N='-n'
ECHO_T=''
EGREP=''
EXEEXT=''
FFMPEG_CFLAGS='-I/usr/include'
FFMPEG_LIBS='-L/usr/lib'
FFMPEG_PREFIX='/usr'
INSTALL_DATA='${INSTALL} -m 644'
INSTALL_PROGRAM='${INSTALL}'
INSTALL_SCRIPT='${INSTALL}'
INSTALL_STRIP_PROGRAM='${SHELL} $(install_sh) -c -s'
LAME_LIBS='-L/usr'
LAME_PREFIX='/usr'
LDFLAGS='-L/usr -L/usr/lib -L/usr/lib/mysql '
LIBOBJS=''
LIBS=''
LTLIBOBJS=''
MAKEINFO='${SHELL} /home/marty/zm-1.21.4/missing --run makeinfo'
MYSQL_CFLAGS='-I/usr/include'
MYSQL_LIBS='-L/usr/lib/mysql'
MYSQL_PREFIX='/usr'
OBJEXT=''
PACKAGE='zm'
PACKAGE_BUGREPORT=''
PACKAGE_NAME=''
PACKAGE_STRING=''
PACKAGE_TARNAME=''
PACKAGE_VERSION=''
PATH_BUILD='/home/marty/zm-1.21.4'
PATH_SEPARATOR=':'
SET_MAKE=''
SHELL='/bin/sh'
STRIP=''
TIME_BUILD='1131741734'
VERSION='1.21.4'
WEB_GROUP='apache'
WEB_PREFIX='/var/www/html/zm'
WEB_USER='apache'
XLIBS=''
ac_ct_CC=''
ac_ct_CXX=''
ac_ct_STRIP=''
am__fastdepCC_FALSE=''
am__fastdepCC_TRUE=''
am__fastdepCXX_FALSE=''
am__fastdepCXX_TRUE=''
am__include=''
am__leading_dot='.'
am__quote=''
am__tar='${AMTAR} chof - "$$tardir"'
am__untar='${AMTAR} xf -'
bindir='${exec_prefix}/bin'
build_alias=''
datadir='${prefix}/share'
exec_prefix='NONE'
host_alias=''
includedir='${prefix}/include'
infodir='${prefix}/info'
install_sh='/home/marty/zm-1.21.4/install-sh'
libdir='${exec_prefix}/lib'
libexecdir='${exec_prefix}/libexec'
localstatedir='${prefix}/var'
mandir='${prefix}/man'
mkdir_p='mkdir -p --'
oldincludedir='/usr/include'
prefix='NONE'
program_transform_name='s,x,x,'
sbindir='${exec_prefix}/sbin'
sharedstatedir='${prefix}/com'
sysconfdir='${prefix}/etc'
target_alias=''
## confdefs.h. ##
#define PACKAGE "zm"
#define PACKAGE_BUGREPORT ""
#define PACKAGE_NAME ""
#define PACKAGE_STRING ""
#define PACKAGE_TARNAME ""
#define PACKAGE_VERSION ""
#define VERSION "1.21.4"
configure: exit 1
thanks marty
1.21.4 install problem
- zoneminder
- Site Admin
- Contact:
I think this
is your problem. Basically it is saying you don't have a compiler on your system, or if you do it's not in any of the directories on your path. I don't know where (or even if) the compiler is on the LiveCD.
Phil
Phil
You need to wait for the package for the live CD. I t is possible to build from source but you really should know what your doing to bring the live CD up to have that ability.
I'll be working on the package here shortly for CTU/FC and LiveCD. Once done Ross will look it over and make sure I didn't miss anything and he will release the package.
Regards,
Cordel
Regards,
Cordel
great news, i dont know enough to build from source
me needs rpm's lol
James
me needs rpm's lol
James
James Wilson
i thought i had speed issues with ctu but its a setup thing, you need to turn off analysing etc and then its as fast as live cd, and supports more hardware
James Wilson
