new version V121.4 ISO ?
-madmax-
Post by -madmax- »
hi,
as much as i learned about linux i still like to get the iso instead of upgrading etc...
anyone got any clue how long it takes to get the new iso ?
rdmelin
Post by rdmelin »
If you're asking about the livecd it will be a couple of weeks before I have time to put out a new version.
Ross
cordel
Post by cordel »
And if your speaking of CTU-ZM distro, I'll have a rpm built by the end of the weekend. I will not be putting out a new CD as I just don't have the bandwidth to do so every time ZM is updated and really there is no need. Running a "yum udate" will fetch and update all packages on it anyway.
I have recieved a considerable donation from sgtdawg towards a 64 bit machine to make a 64 bit distro. When finnished it will have the new zm-1.21.4 package in it.
BTW, Thank you sgtdawg for the huge donation, I wouldn't have been able to start with out it.
Regards,
Cordel
-madmax-
Post by -madmax- »
hi rdmelin,
i was just about getting ready to install a system using 4 server each with 6 ip cam's...
i really would like to use the new version i don't have the time etc to use 1.21.3 livecd and go throught the upgrade...
what a donation help ? and if how much ?
thanks,
-madmax-
jameswilson
Post by jameswilson »
the upgrade rpm will take approx 30 seconds once downloaded to impliment, when i upgraded from 1.21.2 to .3 it was an easy and painless process. Donations to Phil, Corey and ross are always welcome due to the amount of time zm takes in their lives!!
James Wilson
-madmax-
Post by -madmax- »
ok,
i guess i can try! sounds easy enough...
talking about donations...
how would i donate ? to all 3 of those guys or to one and they split them ?
RedFlyer
Post by RedFlyer »
Hi everybody,
I've just upgraded from 1.21.3 to 1.21.4 and i can tell it's a piece of cake !
Thank's again Phil for your good work, and thanks also to the other people contributing to the project.
Best regards,
Oliver
________
Vapormatic vaporizer
zoneminder
Site Admin
Post by zoneminder »
-madmax- wrote: talking about donations...
Either just donate to one of us, and leave a note saying you want it split. Or make separate donations if you prefer. As far as I recall Coreys Paypal email address is cdelasaux[at]computerntelecom<dot>com and Ross's is rdmelin[at]elltel<dot>net. Mine is obviously splashed all over the site :D
Phil
phaksp
Post by phaksp »
cordel wrote: I will not be putting out a new CD as I just don't have the bandwidth to do so every time ZM is updated and really there is no need. Running a "yum udate" will fetch and update all packages on it anyway.
Regards,
Cordel
It's better to put a new CD for download on stable released of course.
For the bandwidth, i can open webspace for free with me isp. Just drop me a mail, and i'll get a Gig free as much as i want.
Only problem, file size limits: 45 mb so... the cd will be cut ect...
But i heard about baliftp which can bipass this problem. testing it ...
Regards,
Sophak
Debian stable 2.6.8-4-k7 kernel - logitech pro 4000 X 3 - zoneminder 1.21.3
Learning Php / Mysql / Java /
-madmax-
Post by -madmax- »
hi phil,
i donated $50 to each account...
thanks again for all the work!
-madmax-
zoneminder
Site Admin
-madmax- wrote:hi phil,
-madmax-
Thank you for this, it's much appreciated.
Phil
rdmelin
Post by rdmelin »
Yes , thank you kindly.
See the announcement forum for a link to an update RPM. A new ISO will be along later this week. :)
cordel
Post by cordel »
Dito here,
Thank you madmax.
Regards,
Cordel
-madmax-
Post by -madmax- »
cool...
can't wait for the ISO! :-)
makes it just so much easier to get new installs setup!
thank you guys!
