Hey,
I upgraded one of my boxes to 1.21.4 - however there's a problem with streaming the live images via zms. Whenever I go to something with the ZMS daemon - the image stream is broken. Within the apache logs I get the following:
==> servers/apache/logs/access_log <==
192.168.0.44 - - [12/Nov/2005:20:57:58 -0500] "GET /cgi-bin/zms?mode=jpeg&event=90910&scale=100&rate=100&maxfps=5&auth=7f56f252730d9832bb064ed8ae974824 HTTP/1.1" 500 601
==> servers/apache/logs/error_log <==
[Sat Nov 12 20:57:58 2005] [error] [client 69.205.170.25] Premature end of script headers: /web/new/cgi-bin/zms
The following is an output in my syslog (and messages, same copy):
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_AUTH_HASH_IPS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_PATH_ZMS, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_CAN_STREAM, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_RAND_STREAM, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_PATH_CAMBOZOLA, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_FAST_IMAGE_BLENDS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_COLOUR_JPEG_FILES, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_JPEG_FILE_QUALITY, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_JPEG_IMAGE_QUALITY, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_OPT_REMOTE_CAMERAS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_NETCAM_REGEXPS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_HTTP_VERSION, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_HTTP_TIMEOUT, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_PATH_FFMPEG, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_FFMPEG_OUTPUT_OPTIONS, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_OPT_NETPBM, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_EXTRA_DEBUG, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_EXTRA_DEBUG_LEVEL, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_EXTRA_DEBUG_LOG, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_PATH_SOCKS, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_PATH_LOGS, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_VIDEO_TIMED_FRAMES, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_VIDEO_LIVE_FORMAT, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_VIDEO_REPLAY_FORMAT, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_POPUP_ON_ALARM, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_OPT_X10, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_X10_DEVICE, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_X10_HOUSE_CODE, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_X10_DB_RELOAD_INTERVAL, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_SOUND_ON_ALARM, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_ALARM_SOUND, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_COMPACT_MONTAGE, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_WEB_MONTAGE_MAX_COLS, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_WEB_MONTAGE_WIDTH, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_WEB_MONTAGE_HEIGHT, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_STRICT_VIDEO_CONFIG, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_CAPTURES_PER_FRAME, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_FILTER_RELOAD_DELAY, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_FILTER_EXECUTE_INTERVAL, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_OPT_UPLOAD, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_UPLOAD_ARCH_FORMAT, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_UPLOAD_FTP_HOST, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_UPLOAD_FTP_LOC_DIR, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_UPLOAD_FTP_TIMEOUT, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_UPLOAD_FTP_DEBUG, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_OPT_EMAIL, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_EMAIL_TEXT, actual type is text]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_OPT_MESSAGE, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch decimal value for ZM_MESSAGE_ADDRESS, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_MESSAGE_TEXT, actual type is text]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_NEW_MAIL_MODULES, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_EMAIL_HOST, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_FROM_EMAIL, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_URL, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_MAX_RESTART_DELAY, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_WATCH_CHECK_INTERVAL, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WATCH_MAX_DELAY, actual type is decimal]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_FORCED_ALARM_SCORE, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch boolean value for ZM_BULK_FRAME_INTERVAL, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_RECORD_EVENT_STATS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_CREATE_ANALYSIS_IMAGES, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_OPT_CONTROL, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_EVENT_SORT_FIELD, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_EVENT_SORT_ORDER, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_CHECK_FOR_UPDATES, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_REFRESH_METHOD, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_DOUBLE_BUFFER, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_LIST_THUMBS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_H_USE_STREAMS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch integer value for ZM_WEB_H_EVENTS_VIEW, actual type is string]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_WEB_M_IMAGE_SCALING, actual type is integer]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_WEB_M_USE_STREAMS, actual type is boolean]
Nov 12 20:56:14 opticscam1 zms[18894]: WAR [Attempt to fetch string value for ZM_WEB_L_REFRESH_CYCLE, actual type is integer]
Any ideas? I've checked permissions on the zms script:
-rwxr-xr-x 2 nobody apache 834105 Jun 25 17:04 nph-zms
-rw-r--r-- 1 nobody apache 268 Jun 25 15:35 printenv
-rw-r--r-- 1 nobody apache 757 Jun 25 15:35 test-cgi
-rwxr-xr-x 2 nobody apache 834105 Jun 25 17:04 zms
Both nobody and apache exist as user/groups.
I tried turning up debugging - no go - help?
1.21.4 - Problems Streaming
Regards,
Ilya Zherebetskiy
Ilya Zherebetskiy
- zoneminder
- Site Admin
- Contact:
