Disclaimer: Test at your own risk, I haven't had the chance to test it. AKA-Hot off the press as they say
Also make note that I'm running into an issue packaging the CVS version of ffmpeg so this zm is packaged and should work with ffmpeg-0.4.8.
As soon as I get the CVS version of ffmpeg packaged I will build on it.
That being said, I'll load it on my machine here in about 12 hrs from the time of this post (The way my lucks been running I'd like to wait for day light as It's that time of the year that my truck got broken into and I got started with ZM to begin with) My test machine is broken and I haven't had the funds to try to fix it. I'd appreciate some feed back and don't hesitate to post here your findings so every one can colaborate.
Once everything checks out Ross and I will get the update for the LiveCD out shortly after.
http://www.computerntelecom.com/pub/linux
Regards,
Cordel
