Page 1 of 1
wireless camera's that work ?
Posted: Thu Nov 17, 2005 1:38 am
by ipguy
hi all
has anyone managed to setup a "wireless" webcam with ZM ?
can you please specify the camera/model and your success story
Posted: Thu Nov 17, 2005 2:06 am
by cordel
You will find just that in the appropraite topics
Hardware Compatibility List
Hardware Queries
Here on the forum.
Regards,
Cordel
Posted: Thu Nov 17, 2005 2:22 am
by ipguy
cordel wrote:You will find just that in the appropraite topics
Hardware Queries
Here on the forum.
Regards,
Cordel
thanks for the pointer, scanned through the posts but unfortunatly just more chatter with peoples problems... no problem though, i'll keep searching
i was just trying to cut-to-the-case by asking if anyone could quickly flick a wireless camera/model that they had success with.
the search continues !
Posted: Thu Nov 17, 2005 3:15 am
by -madmax-
hi,
i have a setup with 5 AXIS 206W...work great, but you need to make sure you have a good wireless coverage!
-madmax-
Posted: Thu Nov 17, 2005 3:23 am
by ipguy
-madmax- wrote:hi,
-madmax-
thanx madmax, this is the kind of reply i was after !!!
Posted: Fri Nov 18, 2005 4:59 pm
by SyRenity
Hi.
I have some D-Link DCS-900W cameras set. They are quite cheap (and have an according visual quality as a result), but work well over a territory of ~50 meter.
