ZM v1.21.4, problems after login.
Posted: Mon Nov 21, 2005 2:52 am
Hello, this version v1.21.4 I have somes problems:
First with mysql, in one insert need more filds, I change for this :
insert into Users VALUES ('','admin',password('admin'),'',1,'View','Edit','Edit','Edit','Edit','','');
This works fine.
Next is ffmpeg, then I get from cvs and work ok.
Next I have problem for login, I try admin/admin and not work, then I remove php5 and instal php4.4 and now I can login
But after I login i have many problems as always show window "Please Donate", any choice about donate, this windows not stop.
Tile in in the webpage is ZM_WEB_TITLE_PREFIX... I have this message in main page : Warning: Division by zero in /var/www/svd/zm_html_view_console.php on line 118
This message in options : Warning: Invalid argument supplied for foreach() in /var/www/svd/zm_html_view_options.php on line 222
And I have other errors too, I go paste urls for images ok.
I cannot start system too becouse I have error, when clic in "Stopped" for start system not work, when I press Apply for start ZM, then "Donate" window show, but ZM not start.
I try too (for test) do chmod 777 -R * in all files(php, html, etc) in web dir installed and yet I have that errors.
My system is ubuntu 5.10 with apache2, mysql4.0, php4.4
My install use this configuration and work ok(without errors in install):
./configure --with-mysql=/usr/include/mysql/ --with-webdir=/var/www/svd/ --with-cgidir=/usr/lib/cgi-bin/ --with-webuser=www-data --with-webgroup=www-data --with-ffmpeg=/usr/local/ --with-lame=/usr/include/lame/
perl zmconfig.pl
mysql mysql < db/zmschema.sql -u root -p
perl ./zmconfig.pl -noi
make
make install
This are two images with errors:
http://www.jp.gegnet.com.br/tmp/zm/zm1.jpeg
http://www.jp.gegnet.com.br/tmp/zm/zm2.jpeg
Juliano
This works fine.
perl zmconfig.pl
make
make install
Juliano
