Problem with permision
germandms
Post by germandms »
many attempts finally I have compiled zm this worked, I have a capturadora kodikom with chip bt878 also works all this in suse 10,0 with kernel 2,6,13, but there is a problem when I enter http://localhost/zm when trying to add a monitor or to make any thing to see properties which is gives the message me of erro 403, that are permissions no to see the file zm.php. clear q is problem with the permissions as they to be these
cordel
Post by cordel »
Check and make sure that the files are owned by your apache user and have read access.
Regards,
Cordel
germandms
Post by germandms »
that archives I must review I must agrgar algun usuary of zm. I can enter index but the archives php
user wwwrun
gruop www
/srv/www/htdocs/zm
/srv/www/cgi-bin/
helpmy please...
JasonH
Post by JasonH »
You're running Suse aren't you?
I've just got the same error on a clean install. It seems to be caused by the zm folder being owned by root. To fix, run the following as root.
cd /srv/www/htdocs
chown wwwrun zm
chgrp www zm
*update* Sorry about this, must have changed more than one thing at once :( After a reboot it seems to be bringing back the same error message as before.
I can fix it by typing http://localhost/zm/zm.php into the browser instead of referencing the symbolic link (index.php). The symlink is owned by root and I can't seem to change this. Anybody else got any clues?
dgsconseil
Post by dgsconseil »
another way to deal with this is to remove the symlink and add zm.php at the end of the line DirectoryIndex index.html index.html.var of your /etc/apache2/httpd.conf
then restart apache
now you can point to http://localhost/zm and zm.php is called by default
