I am using this card:
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... PcY_BIN_IT
and the sources for devices 4 and up showing in red.
I am using the LiveCD setup and with tvtime I can view video on all 8 channels but not thru ZM. I have tried setting the card type to 77 but no change in ZM operation.
Any ideas?
Rick
Edit: Running version 1.21.3
Source /dev/video4 And Up Shows Red
Here is info fromt the zmdc.log
Hopefully this helps.
Rick
here is the scanpic-v dataServer starting at 05/11/21 21:14:20
'zmc -d 6' started at 05/11/21 21:14:23
'zmc -d 6' starting at 05/11/21 21:14:23, pid = 18473
'zmc -d 6' crashed at 05/11/21 21:14:23, exit status 255
'zmc -d 6' starting at 05/11/21 21:14:23, pid = 18475
Can't select: No child processes at /usr/bin/zmdc.pl line 593.
Server starting at 05/11/21 21:14:23
'zmc -d 5' started at 05/11/21 21:14:26
'zmc -d 5' starting at 05/11/21 21:14:26, pid = 18500
'zmc -d 5' crashed at 05/11/21 21:14:27, exit status 255
'zmc -d 5' started at 05/11/21 21:14:27
'zmc -d 5' starting at 05/11/21 21:14:27, pid = 18503
Server starting at 05/11/21 21:14:27
'zmc -d 4' started at 05/11/21 21:14:30
'zmc -d 4' starting at 05/11/21 21:14:30, pid = 18530
'zmc -d 4' crashed at 05/11/21 21:14:30, exit status 255
'zmc -d 4' starting at 05/11/21 21:14:30, pid = 18534
'zmc -d 3' started at 05/11/21 21:14:30
'zmc -d 3' starting at 05/11/21 21:14:30, pid = 18536
'zmc -d 2' started at 05/11/21 21:14:30
'zmc -d 2' starting at 05/11/21 21:14:30, pid = 18540
'zmc -d 1' started at 05/11/21 21:14:30
'zmc -d 1' starting at 05/11/21 21:14:30, pid = 18544
'zmc -d 0' started at 05/11/21 21:14:30
'zmc -d 0' starting at 05/11/21 21:14:30, pid = 18548
'zmc -d 7' starting at 05/11/21 21:14:30, pid = 18552
'zmc -d 7' started at 05/11/21 21:14:30
'zmc -d 7' crashed at 05/11/21 21:14:30, exit status 255
'zmc -d 7' starting at 05/11/21 21:14:30, pid = 18554
'zmc -d 7' crashed at 05/11/21 21:14:31, exit status 255
'zmfilter.pl' starting at 05/11/21 21:14:31, pid = 18558
'zmfilter.pl' started at 05/11/21 21:14:31
'zmaudit.pl -d 900 -y' started at 05/11/21 21:14:31
'zmaudit.pl -d 900 -y' starting at 05/11/21 21:14:31, pid = 18563
'zmwatch.pl' started at 05/11/21 21:14:31
'zmwatch.pl' starting at 05/11/21 21:14:31, pid = 18568
Starting pending process, zmc -d 4
'zmc -d 4' started at 05/11/21 21:14:35
'zmc -d 4' starting at 05/11/21 21:14:35, pid = 18610
'zmc -d 4' crashed at 05/11/21 21:14:35, exit status 255
Starting pending process, zmc -d 7
'zmc -d 7' started at 05/11/21 21:14:36
'zmc -d 7' starting at 05/11/21 21:14:36, pid = 18612
'zmc -d 7' crashed at 05/11/21 21:14:36, exit status 255
'zmc -d 4' starting at 05/11/21 21:14:45, pid = 18622
'zmc -d 4' started at 05/11/21 21:14:45
'zmc -d 4' crashed at 05/11/21 21:14:45, exit status 255
'zmc -d 7' started at 05/11/21 21:14:46
'zmc -d 7' starting at 05/11/21 21:14:46, pid = 18624
'zmc -d 7' crashed at 05/11/21 21:14:46, exit status 255
'zmc -d 4' started at 05/11/21 21:15:05
'zmc -d 4' starting at 05/11/21 21:15:05, pid = 18639
'zmc -d 4' crashed at 05/11/21 21:15:05, exit status 255
'zmc -d 7' started at 05/11/21 21:15:06
'zmc -d 7' starting at 05/11/21 21:15:06, pid = 18641
'zmc -d 7' crashed at 05/11/21 21:15:06, exit status 255
'zmc -d 4' started at 05/11/21 21:15:45
'zmc -d 4' starting at 05/11/21 21:15:45, pid = 18668
'zmc -d 4' crashed at 05/11/21 21:15:45, exit status 255
'zmc -d 7' started at 05/11/21 21:15:46
'zmc -d 7' starting at 05/11/21 21:15:46, pid = 18670
'zmc -d 7' crashed at 05/11/21 21:15:46, exit status 255
'zmc -d 4' started at 05/11/21 21:17:05
'zmc -d 4' starting at 05/11/21 21:17:05, pid = 18722
'zmc -d 4' crashed at 05/11/21 21:17:05, exit status 255
'zmc -d 7' started at 05/11/21 21:17:06
'zmc -d 7' starting at 05/11/21 21:17:06, pid = 18724
'zmc -d 7' crashed at 05/11/21 21:17:06, exit status 255
'zmc -d 4' started at 05/11/21 21:19:45
'zmc -d 4' starting at 05/11/21 21:19:45, pid = 18859
'zmc -d 4' crashed at 05/11/21 21:19:45, exit status 255
'zmc -d 7' starting at 05/11/21 21:19:46, pid = 18861
'zmc -d 7' started at 05/11/21 21:19:46
'zmc -d 7' crashed at 05/11/21 21:19:46, exit status 255
'zmc -d 4' started at 05/11/21 21:25:05
'zmc -d 4' starting at 05/11/21 21:25:05, pid = 19109
'zmc -d 4' crashed at 05/11/21 21:25:05, exit status 255
'zmc -d 7' started at 05/11/21 21:25:06
'zmc -d 7' starting at 05/11/21 21:25:06, pid = 19111
'zmc -d 7' crashed at 05/11/21 21:25:06, exit status 255
Could not find anything /var/messages.pci bus 0x0002 cardnum 0x08 function 0x00: vendor 0x109e device 0x036e
Brooktree Corporation Bt878 Video Capture
STATUS 0x0290 COMMAND 0x0006
CLASS 0x04 0x00 0x00 REVISION 0x11
BIST 0x00 HEADER 0x80 LATENCY 0x20 CACHE 0x00
BASE0 0xf0100008 addr 0xf0100000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x03
pci bus 0x0002 cardnum 0x08 function 0x01: vendor 0x109e device 0x0878
Brooktree Corporation Bt878 Audio Capture
CLASS 0x04 0x80 0x00 REVISION 0x11
BASE0 0xf0101008 addr 0xf0101000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x03
pci bus 0x0002 cardnum 0x09 function 0x00: vendor 0x109e device 0x036e
BASE0 0xf0102008 addr 0xf0102000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x05
pci bus 0x0002 cardnum 0x09 function 0x01: vendor 0x109e device 0x0878
BASE0 0xf0103008 addr 0xf0103000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x05
pci bus 0x0002 cardnum 0x0a function 0x00: vendor 0x109e device 0x036e
BASE0 0xf0104008 addr 0xf0104000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x0b
pci bus 0x0002 cardnum 0x0a function 0x01: vendor 0x109e device 0x0878
BASE0 0xf0105008 addr 0xf0105000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x0b
pci bus 0x0002 cardnum 0x0b function 0x00: vendor 0x109e device 0x036e
BASE0 0xf0106008 addr 0xf0106000 MEM PREFETCHABLE
MAX_LAT 0x28 MIN_GNT 0x10 INT_PIN 0x01 INT_LINE 0x09
pci bus 0x0002 cardnum 0x0b function 0x01: vendor 0x109e device 0x0878
BASE0 0xf0107008 addr 0xf0107000 MEM PREFETCHABLE
MAX_LAT 0xff MIN_GNT 0x04 INT_PIN 0x01 INT_LINE 0x09
pci bus 0x0002 cardnum 0x0c function 0x00: vendor 0x109e device 0x036e
BASE0 0xf0108008 addr 0xf0108000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0c function 0x01: vendor 0x109e device 0x0878
BASE0 0xf0109008 addr 0xf0109000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0d function 0x00: vendor 0x109e device 0x036e
BASE0 0xf010a008 addr 0xf010a000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0d function 0x01: vendor 0x109e device 0x0878
BASE0 0xf010b008 addr 0xf010b000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0e function 0x00: vendor 0x109e device 0x036e
BASE0 0xf010c008 addr 0xf010c000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0e function 0x01: vendor 0x109e device 0x0878
BASE0 0xf010d008 addr 0xf010d000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0f function 0x00: vendor 0x109e device 0x036e
BASE0 0xf010e008 addr 0xf010e000 MEM PREFETCHABLE
pci bus 0x0002 cardnum 0x0f function 0x01: vendor 0x109e device 0x0878
BASE0 0xf010f008 addr 0xf010f000 MEM PREFETCHABLE
Rick
- zoneminder
- Site Admin
- Contact:
I think I got him fixed.
His board has eight chips using only the first input of each one. In his config he setup device 0-7 and put the same in the channel. this worked for the first four devices since the chan was valid. By setting the channles to 0 the first input on the last four devices came on line.
Regards,
Cordel
Regards,
Cordel
