ctu video question
martymoose
ctu video question
Post by martymoose »
played with the live cd
now playing with ctu
by the life of me carnt get a picture with pal setting
just over scan ok with ntsc only bw
on mandrake i change the card = 77
and it worked fine
where is the setting on fc3 to change to a 77 card
thanks again
great program
marty
zoneminder
Site Admin
Post by zoneminder »
It should be in /etc/modules.conf or /etc/modprobe.conf
Phil
martymoose
code in modprobe.conf
alias eth0 via-rhine
alias scsi_hostadapter sata_via
alias snd-card-0 snd-via82xx
options snd-card-0 index=0
install snd-via82xx /sbin/modprobe --ignore-install snd-via82xx && /usr/sbin/alsactl restore >/dev/null 2>&1 || :
remove snd-via82xx { /usr/sbin/alsactl store >/dev/null 2>&1 || : ; }; /sbin/modprobe -r --ignore-remove snd-via82xx
alias char-major-81 bttv
alias usb-controller ehci-hcd
alias usb-controller1 uhci-hcd
do i change the 81 to 77 in (alias char-major-81 bttv)
thanks again
this project is addictive
zoneminder
Site Admin
No, don't change the 81. That would be 'a very bad thing' :lol:
You will need to add another line after that one that says something like
options bttv card=77
though ultimately you may need to add other options. This also assumes you have a singe chip card. For instance this is from my modules.conf
options bttv card=42,42,42,42 pll=1 radio=0 tuner=4 sloppy=1 chroma_agc=1 mmap=1 vbibufs=4 v4l2=1 gbuffers=16
which i think is for a Spectra8.
Also, you will have to unload and reload the bttv driver for this to take effect. Ordinarily the easiest and safest way to do this is via a reboot so it can get a bit laborious if you have to do it a lot.
Phil
martymoose
Code:
mate worked a treat thanks
