we just picked up another potential new client. he wants 15 cameras capturing at 5 fps.
i'm thinking 15 iSights at 320x240 split over 2 firewire busses, for a total video flow right around 30fps per bus at 1/4 the size of a normal, full-frame video feed.
does this seem unreasonable?
we got one isight last night to test. it's working w/ something called "spook", but that creates a mpeg4 stream, not jpeg stills. will try camE and of course zoneminder over the next few days along w/ a second isight and a long extension cable. will report info/stats/success/failure here. i suspect it will work fine.
ieee1394 is apparently well supported on linux. the isight image is great, auto white, auto shutter, comes with audio for $150. only problem (vs fire-i cams) is no thru-port so we can't daisy chain the isights...
--brenden
15 firewire cams @ 5fps each - NUTS ?!
experience?
does anyone on here have experience w/ firewire + zoneminder yet?
