oh crappy
Posted: Thu Nov 24, 2005 3:53 am
ubuntu 5.10 on an amd 64 bit, following directions (I think) w/o doing anything intentionaly weird or stupid:
root@kiwi:/files/zoneminder-1.21.4# make
make all-recursive
make[1]: Entering directory `/files/zoneminder-1.21.4'
Making all in src
make[2]: Entering directory `/files/zoneminder-1.21.4/src'
g++ -g -O2 -Lyes -Lyes/lib -Lyes/lib/mysql -o zmc zmc.o zm.o zm_db.o zm_config.o zm_coord.o zm_box.o zm_image.o zm_event.o zm_zone.o zm_camera.o zm_local_camera.o zm_remote_camera.o zm_file_camera.o zm_monitor.o zm_user.o zm_mpeg.o zm_jpeg.o zm_regexp.o zm_buffer.o zm_debug.o -lmp3lame -lavformat -lavcodec -lavutil -lpcre -lcrypto -lmysqlclient -ldl -lz -ljpeg
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavformat.a(dc1394.o): In function `dc1394_read_header':
: undefined reference to `dc1394_create_handle'
: undefined reference to `dc1394_get_camera_nodes'
: undefined reference to `dc1394_dma_setup_capture'
: undefined reference to `dc1394_destroy_handle'
: undefined reference to `dc1394_start_iso_transmission'
: undefined reference to `dc1394_dma_unlisten'
: undefined reference to `dc1394_dma_release_camera'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavformat.a(dc1394.o): In function `dc1394_read_packet':
: undefined reference to `dc1394_dma_done_with_buffer'
: undefined reference to `dc1394_dma_single_capture'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavformat.a(dc1394.o): In function `dc1394_close':
: undefined reference to `dc1394_stop_iso_transmission'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavformat.a(ogg.o): In function `ogg_write_header':
: undefined reference to `ogg_stream_init'
: undefined reference to `ogg_stream_packetin'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavformat.a(ogg.o): In function `ogg_write_packet':
: undefined reference to `ogg_stream_pageout'
: undefined reference to `ogg_stream_flush'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavformat.a(ogg.o): In function `ogg_write_trailer':
: undefined reference to `ogg_stream_clear'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(dtsdec.o): In function `dts_decode_init':
: undefined reference to `dts_init'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(dtsdec.o): In function `dts_decode_frame':
: undefined reference to `dts_frame'
: undefined reference to `dts_blocks_num'
: undefined reference to `dts_block'
: undefined reference to `dts_samples'
: undefined reference to `dts_syncinfo'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_init':
: undefined reference to `vorbis_info_init'
: undefined reference to `vorbis_encode_init_vbr'
: undefined reference to `vorbis_analysis_init'
: undefined reference to `vorbis_block_init'
: undefined reference to `vorbis_comment_init'
: undefined reference to `vorbis_comment_add_tag'
: undefined reference to `vorbis_analysis_headerout'
: undefined reference to `vorbis_comment_clear'
: undefined reference to `vorbis_encode_init'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_frame':
: undefined reference to `vorbis_analysis_buffer'
: undefined reference to `vorbis_analysis_wrote'
: undefined reference to `vorbis_analysis_blockout'
: undefined reference to `vorbis_analysis'
: undefined reference to `vorbis_bitrate_addblock'
: undefined reference to `vorbis_bitrate_flushpacket'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggvorbis.o): In function `oggvorbis_encode_close':
: undefined reference to `vorbis_block_clear'
: undefined reference to `vorbis_dsp_clear'
: undefined reference to `vorbis_info_clear'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_init':
: undefined reference to `vorbis_synthesis_headerin'
: undefined reference to `vorbis_synthesis_init'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_frame':
: undefined reference to `vorbis_synthesis'
: undefined reference to `vorbis_synthesis_pcmout'
: undefined reference to `vorbis_synthesis_read'
: undefined reference to `vorbis_synthesis_blockin'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggvorbis.o): In function `oggvorbis_decode_close':
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggtheora.o): In function `Theora_decode_frame':
: undefined reference to `theora_decode_packetin'
: undefined reference to `theora_decode_YUVout'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggtheora.o): In function `Theora_decode_end':
: undefined reference to `theora_info_clear'
: undefined reference to `theora_comment_clear'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(oggtheora.o): In function `Theora_decode_init':
: undefined reference to `theora_info_init'
: undefined reference to `theora_decode_header'
: undefined reference to `theora_decode_init'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(libgsm.o): In function `libgsm_init':
: undefined reference to `gsm_create'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(libgsm.o): In function `libgsm_close':
: undefined reference to `gsm_destroy'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(libgsm.o): In function `libgsm_encode_frame':
: undefined reference to `gsm_encode'
/usr/lib/gcc/x86_64-linux-gnu/4.0.2/../../../../lib64/libavcodec.a(libgsm.o): In function `libgsm_decode_frame':
: undefined reference to `gsm_decode'
collect2: ld returned 1 exit status
make[2]: *** [zmc] Error 1
make[2]: Leaving directory `/files/zoneminder-1.21.4/src'
make[1]: *** [all-recursive] Error 1
make[1]: Leaving directory `/files/zoneminder-1.21.4'
make: *** [all] Error 2
any ideas where to start looking ? tia
make all-recursive
Making all in src
