Page 1 of 1
madeariman beach club
Posted: Sun Nov 27, 2005 12:30 pm
by tux
losing and you are not yet at your goal weight, you n eed to back down to the previous level. The the President, write and/or call your congressman, write and/or
Potassium, 17, 108, 113, 264?75 Pour the oils into a clean, dark glass The Atkins Nutrition al Approach can and has correc ted these ser ious risk f actors
Me sonaba ya su nombre pero a raiz de verla actuar junto a Gillian en Nueva York para principiantes le puse rostro pues bien; informбndome sobre una cosa para la radio me topo con esta noticia de l
But the only help that ever showed up was me. blend onto the palm of one hand. achievement, creative vision, service to others, and who guides one unerringly to the attainment of
Posted: Sun Nov 27, 2005 10:54 pm
by cordel
So for your host name: camserver.home.net
Remote port: 8192
host path: cameras/camera1.jpg
Should get you going.
Regards,
Cordel
Posted: Mon Nov 28, 2005 11:42 am
by tux
thanks cordel
My first problem was I don´t know how see jpeg format of my ip cam, because when I introduce in URL * embedded web server of ip cam redirect to:
http://*/top.htm?Currenttime=2005-11-28%2011:08:14
Welcome to the Internet Camera
* View Video - ActiveX Mode
* View Video - Java Mode
* System Administration
STATIC CAPTURE PIC HERE
- I view html source and the url I need is
http://*/IMAGE.JPG
- But cannot function with zm:
SERVERNAME *
PORT 80
HOST PATH IMAGE.JPG or /IMAGE.JPG
Remote image colors 8 bits
the result : CAMARA_IP Monitor * (RED :evil: )
- But if I introduce
SERVERNAME *
PORT 80
HOST PATH */IMAGE.JPG
the result : CAMARA_IP Monitor * (YELLOW :wink: )
but I cannot see any image in zm (Estado: Pasivo - 0.00 fps)
- In Options
ZM_OPT_REMOTE_CAMERAS select
ZM_NETCAM_REGEXPS select
ZM_HTTP_VERSION 1.1 (I try so with 1.0)
ZM_HTTP_UA Zonemider ( I try so with Netscape)
ZM_HTTP_TIMEOUT 2500
What I try ?
regards
thanks
Posted: Mon Nov 28, 2005 3:07 pm
by jameswilson
can you put this cam public i can have a try if you like?
Posted: Mon Nov 28, 2005 3:47 pm
by tux
ok
IP *
listen port 8080
IP cam passw without password
JPEG PATH /IMAGE.JPG
thanks
Posted: Mon Nov 28, 2005 3:49 pm
by jameswilson
i get nothing on that ip:port number
Posted: Mon Nov 28, 2005 3:54 pm
by tux
check in port 80
Posted: Mon Nov 28, 2005 4:08 pm
by jameswilson
already did nothing on either port
Posted: Mon Nov 28, 2005 4:13 pm
by tux
I go to restart router an disable firewall anything, and redicrect tcp and udp
Posted: Mon Nov 28, 2005 4:19 pm
by jameswilson
ok i have image now give me a minute
Posted: Mon Nov 28, 2005 4:28 pm
by jameswilson
ok
Monitor Tab
source = remote
Source Tab
Remote Host Name = Local ip (i used 81.202.199.187)
remote host port = 80
Host Path = /image.jpg (note leading /)
Remote colours 24 bit colour
Capture width = 320
capture Height = 240
Id also alter your max fps to say 2 while you get used to what each setting means
Posted: Mon Nov 28, 2005 5:02 pm
by tux
Thanks for all jameswillson
Runs you ip cam well in your zm with this values?
I tried with this values yesterday and today and dont´t run, I will try to install zm in ubuntu, I running a livecd install in hd.
You can see my zm
http://*/
Yo can see my ip cam here
http://*:
If you like, you can modifty all you like don´t worry.
thanks
Posted: Mon Nov 28, 2005 5:08 pm
by jameswilson
i get about 1fps from you in my zm but i have disabled it now to preserve mine and your bandwidth
Goodluck I got started with livecd and i still use it now.
Posted: Mon Nov 28, 2005 6:40 pm
by tux
Arggggggg :shock: , I reboot zm computer and ip cam is runing ok
- My problem was because if you change configuration of remote cameras you need to reboot zm daemon, I have well configured but so need reboot daemond so I see in red (the name of camera). In analogic(local) cameras I don´t need reboot zm daemon for change confgiguration.
- Only can runs 2.67 fps, but is running :D
thanks to all for help.
Posted: Mon Nov 28, 2005 6:42 pm
by jameswilson
if you want i higher framerate you will need an mjpeg stream not jpg grabs plus its a wireless cam isnt it so you will ultimatly be limited by that
and your welcome
