I just built a dedicated ZM box. I am running Red Hat 7.1 and ZM 1.21.4 source. When I try to run ./configure to set up the mysql db, or zminit, it always says access denied due to incorrect password. It is trying to use YES as the password even though zm.conf and zmconfig.txt both show the user/pass that I put in.
Any ideas?
Thanks.
Jason
Trouble setting up db
- Contact:
i think you need the root password for the db here
it wont always be your root login password, have you tried leaving it blank i think the default passward is that
James
James
James Wilson
- zoneminder
- Site Admin
- Contact:
