Can't execute: Table 'zoneminder.Config' doesn't exist at zm
broken
Post by broken »
I followed the codumentation correctly and did everything as asked in the zmconfig.pl setup scripts but when I try to setup the db I get this.
zoneminder
Site Admin
Re: Can't execute: Table 'zoneminder.Config' doesn't exist a
Post by zoneminder »
Hi Brian,
Which version of zm are you using?
When you ran mysql with zmschema.sql did you get any errors?
Phil,
broken
Post by broken »
Nevermind I fixed it... :-) I had set some privilages wrong in the db
