problem running zmc
Posted: Tue Oct 28, 2003 10:30 pm
I have compiled and installed zoneminder with no problems.
I configured a monitor through the web front end but when I came to view the image from the webcam there was nothing there.
I started to run through the trouble shooting section of the readme and got up to checking the zmc utility. I think this is failing on my system but not to sure why.
This is a dump of the var/log/messages file when I run the command:-
"zmc --device /dev/video0"
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [Debug Level = 0, Debug Log = ]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [Got 1 monitors]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [X:0]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [Y:0]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [W:640]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [H:480]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [P:4]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [D:24]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [B:42496]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [h:32768]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [Cl:49152]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [Cn:0]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [vmb.frames = 2]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [vmb.size = 1843216]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [C:0]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [F:0]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [Fl:0]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [T:2]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [W:352]
Oct 28 22:29:23 mdlinux zmc-d0[4917]: INF [H:288]
Oct 28 22:29:24 mdlinux zmc-d0[4917]: INF [B:42496]
Oct 28 22:29:24 mdlinux zmc-d0[4917]: INF [h:32768]
Oct 28 22:29:24 mdlinux zmc-d0[4917]: INF [Cl:49152]
Oct 28 22:29:24 mdlinux zmc-d0[4917]: INF [Cn:0]
Oct 28 22:29:24 mdlinux zmc-d0[4917]: INF [monitor mode=1]
Oct 28 22:29:24 mdlinux zmc-d0[4917]: INF [shm.size=30413248]
Oct 28 22:29:24 mdlinux zmc-d0[4917]: ERR [Can't shmget: Invalid argument]
Oct 28 22:29:29 mdlinux kernel: vfree(): sleeping in interrupt!!
Oct 28 22:29:29 mdlinux kernel: c02e3f18 c0227060 c65fe5fc c65fe400 c88c4625 c88d3000 001c2010 c65fe5fc
Oct 28 22:29:29 mdlinux kernel: c65fe400 c65fe400 c88c4742 c65fe400 c65fe400 c88c46fc c0329470 c011e6ef
Oct 28 22:29:29 mdlinux kernel: c65fe400 c0330440 00000000 c0329470 00000000 c011b26f c011b1a6 00000000
Oct 28 22:29:29 mdlinux kernel: Call Trace: [<c88c4625>] ov51x_do_dealloc [ov511] 0x45
Oct 28 22:29:29 mdlinux kernel: [<c88c4742>] ov51x_buf_callback [ov511] 0x46
Oct 28 22:29:29 mdlinux kernel: [<c88c46fc>] ov51x_buf_callback [ov511] 0x0
Oct 28 22:29:29 mdlinux kernel: [<c011e6ef>] timer_bh [kernel] 0x20b
Oct 28 22:29:29 mdlinux kernel: [<c011b26f>] bh_action [kernel] 0x1b
Oct 28 22:29:29 mdlinux kernel: [<c011b1a6>] tasklet_hi_action [kernel] 0x52
Oct 28 22:29:29 mdlinux kernel: [<c011afc3>] do_softirq [kernel] 0x47
Oct 28 22:29:29 mdlinux kernel: [<c010992c>] do_IRQ [kernel] 0x90
Oct 28 22:29:29 mdlinux kernel: [<c0105000>] stext [kernel] 0x0
Oct 28 22:29:29 mdlinux kernel: [<c0106b74>] default_idle [kernel] 0x0
Oct 28 22:29:29 mdlinux kernel: [<c0106b97>] default_idle [kernel] 0x23
Oct 28 22:29:29 mdlinux kernel: [<c0106bdc>] cpu_idle [kernel] 0x20
Oct 28 22:29:29 mdlinux kernel: c02e3f1c c0227060 c65fe5fc c65fe400 c88c4641 c8a97000 c65fe5fc c65fe400
Oct 28 22:29:29 mdlinux kernel: c65fe400 c88c4742 c65fe400 c65fe400 c88c46fc c0329470 c011e6ef c65fe400
Oct 28 22:29:29 mdlinux kernel: c0330440 00000000 c0329470 00000000 c011b26f c011b1a6 00000000 00000001
Oct 28 22:29:29 mdlinux kernel: Call Trace: [<c88c4641>] ov51x_do_dealloc [ov511] 0x61
Oct 28 22:29:30 mdlinux kernel: [<c010992c>] do_IRQ [kernel] 0x90
Oct 28 22:29:30 mdlinux kernel: [<c0105000>] stext [kernel] 0x0
Oct 28 22:29:30 mdlinux kernel: [<c0106b74>] default_idle [kernel] 0x0
Oct 28 22:29:30 mdlinux kernel: [<c0106b97>] default_idle [kernel] 0x23
Oct 28 22:29:30 mdlinux kernel: [<c0106bdc>] cpu_idle [kernel] 0x20
Oct 28 22:29:30 mdlinux kernel: vfree(): sleeping in interrupt!!
Oct 28 22:29:30 mdlinux kernel: c02e3f1c c0227060 c65fe5fc c8a97000 c88c465c c8b7a000 c65fe5fc c65fe400
Oct 28 22:29:30 mdlinux kernel: c65fe400 c88c4742 c65fe400 c65fe400 c88c46fc c0329470 c011e6ef c65fe400
Oct 28 22:29:30 mdlinux kernel: c0330440 00000000 c0329470 00000000 c011b26f c011b1a6 00000000 00000001
Oct 28 22:29:30 mdlinux kernel: Call Trace: [<c88c465c>] ov51x_do_dealloc [ov511] 0x7c
Oct 28 22:29:30 mdlinux kernel: [<c88c4742>] ov51x_buf_callback [ov511] 0x46
Oct 28 22:29:30 mdlinux kernel: [<c88c46fc>] ov51x_buf_callback [ov511] 0x0
Oct 28 22:29:30 mdlinux kernel: [<c011e6ef>] timer_bh [kernel] 0x20b
Oct 28 22:29:30 mdlinux kernel: [<c011b26f>] bh_action [kernel] 0x1b
Oct 28 22:29:30 mdlinux kernel: [<c011b1a6>] tasklet_hi_action [kernel] 0x52
Oct 28 22:29:30 mdlinux kernel: [<c011afc3>] do_softirq [kernel] 0x47
Oct 28 22:29:31 mdlinux kernel: [<c0106bdc>] cpu_idle [kernel] 0x20
"Don't like the look of all them kernel hex numbers!!!"
The webcam I'm using is a USB trust spacec@m 200 which uses the ov511 driver.
The web cam works fine and I am able to capture images using the utility w3com no problems at all.
The system that I'm running is a Redhat 7.3 install
heres a dump from the /proc/version file:-
Linux version 2.4.18-3 (bhcompile@stripples.devel.redhat.com) (gcc version 2.96 20000731 (Red Hat Linux 7.3 2.96-110)) #1 Thu Apr 18 07:31:07 EDT 2002
Anybody have any ideas to what is wrong?
Many thanks
Matt
Many thanks
Matt
