WHen moving from 0.4.8 to 0.4.9 is there any difference in the command line used to generate videos from stills. If i use 0.4.9 it fails with an incorrect colour header, but the same command works 0.4.8 but doesnt play properly.
James
ffmpeg
ffmpeg
James Wilson
- zoneminder
- Site Admin
- Contact:
whats the command you use or are you using the api to control ffmpeg?
James Wilson
