Page 1 of 1
ZM on SME7beta8 (based on centos4.2) with yum
Posted: Thu Dec 01, 2005 6:39 am
by chaapaï
hello all!!
Well, i haved rebuild ZM-1.21.4 for SME7beta8 (based on centos4.2 with kernel 2.6.9-22.0.1)
If you want install zm with yum:
open a ssh session and tape (or edit /home/db/yum_repository )
# echo "contribchaapai=repository|BaseURL|ftp://ftp.chaapai.homelinux.net/yum-smeserver/7.0beta8/smechaapai\/$basearch|EnableGroups|0|GPGCheck|0|Name|SME Server - Chaapai contribs|status|enabled">>/home/e-smith/db/yum_repositories
# /sbin/e-smith/expand-template /etc/yum.conf
check the result in /etc/yum.conf :
[contribchaapai]
name=SME Server - Chaapai contribs
baseurl=ftp://ftp.chaapai.homelinux.net/yum-smeserver/7.0beta8/smechaapai/$basearch
gpgcheck=0
enablegroups=0
an for install zm with X10 tape
yum install zm-X10
I have rebuild bttv driver , qc-usb driver for kernels
-kernel-module-bttv-0.9.15 ( or kernel-hugemem-module-bttv-0.9.15-1_2.6.9_22.0.1.EL.i686.rpm
or kernel-smp-module-bttv-0.9.15-1_2.6.9_22.0.1.EL.i686.rpm )
-kernel-module-qc-usb-0.6.3 (
-ffmpeg-0.4.9-cvs20051119
-lot of perl-modules.......
just tape yum install kernel-module-bttv-0.9.15 :D
rpms and srpms here :
ftp://ftp.chaapai.homelinux.net/yum-sme ... mechaapai/
Nice job , Phil, I love you :D:D:D
Chaapai
Posted: Thu Dec 01, 2005 1:07 pm
by zoneminder
Hi Chaapaï, calm down a bit :lol:
Thanks for doing, hopefully it will be useful to a lot of people.
Cheers
Phil
Posted: Thu Dec 01, 2005 2:29 pm
by guidouil
Hello Chaapaï, thx for your work, but I think I have a problem... (et oui ya toujours des lamers ;) )
here is what I get when I try to yum install zm-x10
ftp://ftp.chaapai.homelinux.net/yum-smeserver/7.0beta8/smechaapai\/repodata/repomd.xml: [Errno 4] IOError: [Errno ftp error] 550 smechaapai\: No such file or directory
Trying other mirror.
Cannot open/read repomd.xml file for repository: contribchaapai
failure: repodata/repomd.xml from contribchaapai: [Errno 256] No more mirrors to try.
Error: failure: repodata/repomd.xml from contribchaapai: [Errno 256] No more mirrors to try.
please help stp
Edited / fixed :
ok I got it working it was because of the backslash ...
I just edited the /home/e-smith/db/yum_repositories and corrected the pass with the /$basesearch and make sure that nano did not add some lines to that and now everything work well :D thx Chaapaï and sorry for my noobnes ;)
Great Work Chaapai !!!!!!
Posted: Sat Dec 03, 2005 6:04 am
by wa4bro
This is actually what I got to work as a DB entry for SME
Just cut and paste after command prompt.
From the Command Prompt#
------ Cut and Paste Below this line ---------
db yum_repositories set Chaapai repository \
BaseURL ftp://ftp.chaapai.homelinux.net/yum-sme ... apai/i386/ \
EnableGroups 1 \
GPGCheck 0 \
Name 'SME Server - Chaapai contribs' \
status enabled
----------- END Cut and Paste ------------
This will add Chaapai 's YUM Repository to the Database for YUM in the SME Server.
After installing Chaapai's Repository go to the command prompt and type:
(This adds the Kernel Module needed for BTTV as it is not included in the CentOS standard kernel release.)
Then Type:
yum install ZM
(This installs the lastest version of Zoneminder, creates the web directory, mysql database etc)
If you need to install QC usb drivers type:
yum install kernel-module-qc-usb
I suggest you go ahead and reboot your SME server then after restart
http://yourserver.???/zoneminder
Info on SME Server at http://contribs.org
Latest Beta Version 7b8 ISO image at http://distro.ibiblio.org/pub/linux/dis ... 0beta8.iso
SME 7 is Based on CentOS version 4.2 and is a complete Small Business Class Server with MTA mail client, webmail, SMB windows sharing server, gateway and is typically administered completely from a web interface along with console availability. ( NO XWindows).
**** WARNING **** SME is a standalone server. The install takes over the complete drive and installs in about 10 mins or less on most modern hardware. You can not share a drive with another OS.
It runs ZONEMINDER quite well too!
Enjoy and Many Thanks to Chaapai for his fantastic work in intergrating ZM for the SME server!
Dan
Posted: Sat Dec 03, 2005 10:00 pm
by martymoose
hi
whats the min specs for sme
also anyone get a canon pixma ip4000 printer working with sme
Re: Great Work Chaapai !!!!!!
Posted: Sun Dec 04, 2005 5:17 am
by martymoose
wa4bro wrote:This is actually what I got to work as a DB entry for SME
EnableGroups 1 \
GPGCheck 0 \
status enabled
Then Type:
yum install ZM
Dan
this is what i got to work
[contribchaapai]
enabled=1
baseurl=ftp://ftp.chaapai.homelinux.net/yum-sme ... /$basearch
gpgcheck=0
enablegroups=0
Posted: Sun Dec 04, 2005 6:33 am
by martymoose
mate great work
this what i was waiting for
Posted: Sun Dec 04, 2005 6:36 pm
by chaapaï
hello all !!
Sorry for my late, (i search new job... :roll:)
well, the backslash is in the command because i'm doing a "echo" command and for include "$" i need a "\" , $basearch is arch (i386).
You can also use the command by wa4bro (thanks)
But You can edit manually /home/e-smith/db/yum_repositories
and add/check line :
smechaapai=repository|BaseURL|ftp://ftp.chaapai.homelinux.net/yum-smeserver/7.0beta8/smechaapai/$basearch|EnableGroups|yes|GPGCheck|no|Name|SME Server - Chaapai contribs|Visible|yes|status|enabled
(or add another yum link)
AND tape
for re-create /etc/yum.conf
My server ( http://www.chaapai.homelinux.net ) is a old duron 1000 with 640mo sdram133 ( 0 swap) with 2dd 40go raid 01 ata100 (last technologie server :D)
1 quickcam express "superglue" and a xguard running with 3 cams b/w
cpu usage is 15-20%
phpsysinfo: http://www.chaapai.homelinux.net/w_stats/index.php
And monitoring system(cpu dd ftp zoneminder usage) : (sorry for cpu-sys temp, but soltek sl-75kav motherboard) http://www.chaapai.homelinux.net/w_stat ... monitoring
So my old config was compaq deskpro pii400 with 256mo (max because old motherboard and new ram) ata33 (oucht!!!) and cpu-usage 60-70%, slow very slow with hdd access..
problems...
Posted: Tue Sep 19, 2006 3:23 pm
by leprox
i follow all steps but when y use yum u have this erros..
[root@backup db]# yum install zm-X10
WARNING: Additional commands may be required after running yum
Setting up Install Process
Setting up repositories
smeaddons 100% |=========================| 951 B 00:00
smeos 100% |=========================| 951 B 00:00
smeupdates 100% |=========================| 951 B 00:00
Reading repository metadata in from local files
Parsing package install arguments
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Package zm-X10.i386 0:1.21.4-01.sme7 set to be updated
--> Running transaction check
--> Processing Dependency: perl(X10::ActiveHome) for package: zm-X10
--> Processing Dependency: perl-Astro-SunTime for package: zm-X10
--> Processing Dependency: perl-X10 for package: zm-X10
--> Processing Dependency: zm = 1.21.4 for package: zm-X10
--> Restarting Dependency Resolution with new changes.
---> Package perl-X10.noarch 0:0.03-1 set to be updated
---> Package zm.i386 0:1.21.4-01.sme7 set to be updated
---> Package perl-Astro-SunTime.noarch 0:0.01-1 set to be updated
--> Processing Dependency: perl-Archive-Zip for package: zm
--> Processing Dependency: libavformat.so for package: zm
--> Processing Dependency: zm-lat_ibay = 1.21.4 for package: zm
--> Processing Dependency: perl(Time::ParseDate) for package: perl-X10
--> Processing Dependency: libmp3lame.so.0 for package: zm
--> Processing Dependency: perl(Device::SerialPort) for package: perl-X10
--> Processing Dependency: ffmpeg >= 0.4.9 for package: zm
--> Processing Dependency: libavutil.so for package: zm
--> Processing Dependency: perl-Compress-Zlib for package: zm
--> Processing Dependency: perl-Device-SerialPort for package: zm
--> Processing Dependency: perl(Time::ParseDate) for package: perl-Astro-SunTime
--> Processing Dependency: lame >= 3.96.1 for package: zm
--> Processing Dependency: perl-Time-modules for package: zm
--> Processing Dependency: perl(Device::SerialPort) for package: zm
--> Processing Dependency: libavcodec.so for package: zm
--> Processing Dependency: perl-MIME-Lite >= 3.01-2.2 for package: zm
---> Package perl-Compress-Zlib.i386 0:1.41-1.2.el4.rf set to be updated
---> Package perl-MIME-Lite.noarch 0:3.01-2.2.el4.rf set to be updated
---> Package perl-Time-modules.noarch 0:2003.1126-1 set to be updated
---> Package zm-lat_ibay.i386 0:1.21.4-01.sme7 set to be updated
---> Package ffmpeg.i386 0:0.4.9-cvs20051119 set to be updated
---> Package perl-Device-SerialPort.i386 0:1.002-1.2.el4.rf set to be updated
---> Package perl-Archive-Zip.noarch 0:1.16-1 set to be updated
---> Package lame.i386 0:3.96.1-el42 set to be updated
--> Processing Dependency: libtheora.so.0 for package: ffmpeg
--> Processing Dependency: libvorbisenc.so.2 for package: ffmpeg
--> Processing Dependency: libfaac.so.0 for package: ffmpeg
--> Processing Dependency: libvorbis.so.0 for package: ffmpeg
--> Processing Dependency: libSDL-1.2.so.0 for package: ffmpeg
--> Processing Dependency: libX11.so.6 for package: ffmpeg
--> Processing Dependency: libogg.so.0 for package: ffmpeg
--> Processing Dependency: libxvidcore.so.4 for package: ffmpeg
--> Processing Dependency: libImlib2.so.1 for package: ffmpeg
--> Processing Dependency: libgsm.so.1 for package: ffmpeg
---> Package libtheora.i386 0:1.0alpha4-2 set to be updated
---> Package faac.i386 0:1.24-1.2.el42 set to be updated
---> Package imlib2.i386 0:1.2.1-1 set to be updated
---> Package xvidcore.i386 0:1.1.0-beta2.1.el42 set to be updated
---> Package gsm.i386 0:1.0.10-0.el42 set to be updated
--> Processing Dependency: libX11.so.6 for package: imlib2
--> Processing Dependency: libungif.so.4 for package: imlib2
--> Processing Dependency: libXext.so.6 for package: imlib2
--> Finished Dependency Resolution
Error: Missing Dependency: libvorbisenc.so.2 is needed by package ffmpeg
Error: Missing Dependency: libvorbis.so.0 is needed by package ffmpeg
Error: Missing Dependency: libSDL-1.2.so.0 is needed by package ffmpeg
Error: Missing Dependency: libX11.so.6 is needed by package ffmpeg
Error: Missing Dependency: libogg.so.0 is needed by package ffmpeg
Error: Missing Dependency: libX11.so.6 is needed by package imlib2
Error: Missing Dependency: libungif.so.4 is needed by package imlib2
Error: Missing Dependency: libXext.so.6 is needed by package imlib2
No new rpms were installed. No additional commands are required.
