James the cycle view issue does seem to be solved if you put the max number of cams to the max number of CONSECUTIVE cams defined.
Seems it burps when it hits a cam that is blank and not defined.
I don't know if you want to explain that on the cycle view setup screen or
have the code check and skip any cam that is not defined (better, but more work) <G>
Dan
Cycle View
i agree with the latter it should be as fool proof as possible i will put it on the (now sparse lol) list of things to fix
Glad its sorted
Did the url refresh rate help you at all?
Glad its sorted
James Wilson
