Live Streaming with Flash swf: working; Quicktime question
Posted: Sun Dec 04, 2005 11:27 pm
Hello all,
As this is my first post, kudos to Phil for a great tool!
I recently started evaluating ZM for a project needing reasonable quality live streaming over consumer broadband internet connections, as well as record, playback and download. I also need compatibilty with browsers on Win and Mac. So .asf live streaming was not acceptable for me since, as far as I can tell, it does not work on a Mac "out of the box."
So I've been trying other live stream formats, but ZM kept trying to load them into WMP no matter what I tried. Looking at the code in zm_html_view_watchfeed.php I found (starting line 96):
As I read this, if the browser is on Windows, MediaPlayer is loaded to try and read the stream no matter what the actual format. Otherwise, mime type "video/mpeg" is selected on all other platforms, again no matter what the actual format.
Since I'm trying formats compatible out of the box with both Win and Mac, I've focused on Quicktime (.mov, .mp4) and Flash (.swf). And of course I need the browser to load the correct player. So I have changed the above code as follows:
This works fine to load and stream to WMP (.asf) or Flash (.swf) players on Win; on Mac .swf works great also. As a bonus, Flash avoids some of the other problems reported here with .asf: there's no delay in starting up the stream and at least in my limited testing, it does not lose time when run continuously.
Although Quicktime loads, I have not succeded yet to get live streaming working with .mp4. And with .mov I get this error from zms:
If someone has sorted this out, please le me know.
Thanks again for the fine project.
regards,
Mickey
<?php
if ( $mode == "stream" )
if ( ZM_VIDEO_STREAM_METHOD == 'mpeg' && ZM_VIDEO_LIVE_FORMAT )
$stream_src = getStreamSrc( array( "mode=mpeg", "monitor=".$mid, "s
cale=".$scale, "bitrate=".ZM_WEB_VIDEO_BITRATE, "maxfps=".ZM_WEB_VIDEO_MAXFPS, "for
mat=".ZM_VIDEO_LIVE_FORMAT ) );
if ( isWindows() )
<object id="MediaPlayer" width="<?= reScale( $monitor['Width'], $scale ) ?>" height
="<?= reScale( $monitor['Height'], $scale ) ?>"
classid="CLSID:22D6F312-B0F6-11D0-94AB-0080C74C7E95"
codebase="http://activex.microsoft.com/activex/controls/mplayer/en/nsmp2inf.cab#Ver
sion=6,0,02,902"
standby="Loading Microsoft Windows Media Player components..."
type="application/x-oleobject">
<param name="FileName" value="<?= $stream_src ?>">
<param name="autoStart" value="1">
<param name="showControls" value="0">
<embed type="application/x-mplayer2"
pluginspage = "http://www.microsoft.com/Windows/MediaPlayer/"
src="<?= $stream_src ?>"
name="MediaPlayer"
height="<?= reScale( $monitor['Height'], $scale ) ?>"
autostart="1"
showcontrols="0">
</embed>
</object>
<?php
else
<embed type="video/mpeg"
autostart="1"
showcontrols="0">
</embed>
<?php
$stream_src = getStreamSrc( array( "mode=mpeg", "monitor=".$mid, "scale=".$scale, "bitrate=".ZM_WEB_VIDEO_BITRATE, "maxfps=".ZM_WEB_VIDEO_MAXFPS, "format=".ZM_VIDEO_LIVE_FORMAT ) );
//MRR Following switch code to match embed type to file types being used
switch ( ZM_VIDEO_LIVE_FORMAT )
case "asf" :
print "<embed type=\"video/x-ms-asf\" ";
break;
case "swf" :
print "<embed type=\"application/x-shockwave-flash\" ";
break;
case "mp4" :
print "<embed type=\"video/mp4\" ";
break;
case "mov" :
print "<embed type=\"video/quicktime\" ";
break;
default :
//MRR Note - leaving blank forces browser to determine mime type from suffix of the src attribute
print "<embed ";
break;
autostart="1"
showcontrols="0">
</embed>
Unable to determine mime type for 'mov' format, using 'video/mpeg' as default
regards,
Mickey
