I have added an extra 'if' block around the existing authentication code which authenticates the supplied credentials against the active directory (using the ntlm_auth command).
I then took the password criteria out of the SQL statement. (see code below)
I have done things this way as it required minimal changes, allowing me to continue using the permissions system of ZM.
Can anyone suggest a better way to achieve this? I've really just made a quick hack to get it going.
Cheers,
-Kent
The following code was modified around line 40 of zm_funcs.php:
exec('/usr/bin/ntlm_auth --username=' . escapeshellarg($username) . ' --password=' . escapeshellarg($password), $stdOut, $result);
if ($result == 0) {
$sql = "select * from Users where Username = '".mysql_escape_string($username)."' and Enabled = 1";
$result = mysql_query( $sql );
