Page 1 of 1
Repeating bogus events
Posted: Tue Dec 06, 2005 6:39 pm
by mnmis
I have been seeing the following bad entries in my events window for the last 3 days.
Motion 12/31 18:00:00 17199176.02 64 50 4175 83 93
The date and time are always 12/31 18:00:00 with the large number for the duration.
Any ideas on what could be wrong?
Thanks.
Posted: Tue Dec 06, 2005 8:48 pm
by zoneminder
I've not seen this kind of thing before. Are you able to go into the DB and extract a bit more detail?
Phil
Posted: Tue Dec 06, 2005 11:04 pm
by mnmis
What detail would you like?
Posted: Tue Dec 06, 2005 11:08 pm
by jameswilson
you havnt got the zone so sensitive its constantly in alarm have you? when you view the stream does it goto idle?
James
ps and we would be after the relevant log files like starting new event, capturing at x fps etc etc
James
Posted: Wed Dec 07, 2005 12:20 pm
by mnmis
No I don't have the zones too sensitive. The thing is that it was working just fine until a couple of day ago.
A couple of things I noticed.
When I look at the stills of the bad entries, there is a lot of black frames intermixed with the same frame of a valid capture over and over.
Also, this is a wireless web camera which I think it is loosing connection ocasionally. Could this be the cause?
Thanks.
Posted: Wed Dec 07, 2005 12:28 pm
by jameswilson
i would think so yes as this will be causing no end of grief it it keeps appearing and disapearing. You will have some errors in you rlogs
Posted: Wed Dec 07, 2005 12:58 pm
by mnmis
This is a error I am seeing in the zmaudit log.
12/07/05 02:26:02.756219 zmaudit_d900_y[24832].INF [Found orphaned statistic records for event '1673']
12/07/05 02:26:02.756350 zmaudit_d900_y[24832].INF [deleting]
12/07/05 02:26:02.756912 zmaudit_d900_y[24832].INF [Found orphaned statistic records for event '1674']
12/07/05 02:26:02.757041 zmaudit_d900_y[24832].INF [deleting]
12/07/05 02:26:02.757825 zmaudit_d900_y[24832].INF [Found orphaned statistic records for event '1675']
12/07/05 02:26:02.757953 zmaudit_d900_y[24832].INF [deleting]
12/07/05 02:26:02.758860 zmaudit_d900_y[24832].INF [Found orphaned statistic records for event '1676']
12/07/05 02:26:02.758992 zmaudit_d900_y[24832].INF [deleting]
12/07/05 02:26:02.759685 zmaudit_d900_y[24832].INF [Found orphaned statistic records for event '1677']
12/07/05 02:26:02.759815 zmaudit_d900_y[24832].INF [deleting]
12/07/05 02:26:02.760378 zmaudit_d900_y[24832].INF [Found orphaned statistic records for event '1678']
12/07/05 02:26:02.760508 zmaudit_d900_y[24832].INF [deleting]
Any sugestions on how to minimize the problem?
Posted: Wed Dec 07, 2005 1:00 pm
by zoneminder
Those are not errors, just informative messages so don't worry about that. Anything in /var/log/messages?
If you can just do a manual 'select' from the Events table for an event or two with this problem then it might give a bit more info.
Phil
Posted: Wed Dec 07, 2005 4:09 pm
by mnmis
How do you do a "Manual Select"?
Posted: Wed Dec 07, 2005 4:27 pm
by jameswilson
use the filter window the select some entries thathave this problem then copy and paste the data i assume he means
Posted: Wed Dec 07, 2005 5:05 pm
by mnmis
Message file logs
Dec 7 10:44:17 tanserver zmc_m2[19430]: INF [BackDoor: 2000 - Capturing at 5.99 fps]
Dec 7 10:45:18 tanserver zmc_m2[19430]: INF [Got TERM signal, exiting]
Dec 7 10:45:18 tanserver zmc_m2[19794]: INF [Debug Level = 0, Debug Log = <none>]
Dec 7 10:45:18 tanserver zmc_m2[19794]: INF [Starting Capture]
Dec 7 10:45:54 tanserver zma_m2[24819]: INF [BackDoor: 4357000 - Processing at 5.68 fps]
Dec 7 10:47:08 tanserver zmc_m2[19794]: INF [Got TERM signal, exiting]
Dec 7 10:47:08 tanserver zmc_m2[19865]: INF [Debug Level = 0, Debug Log = <none>]
Dec 7 10:47:08 tanserver zmc_m2[19865]: INF [Starting Capture]
Dec 7 10:48:18 tanserver zmc_m2[19872]: INF [Debug Level = 0, Debug Log = <none>]
Dec 7 10:48:18 tanserver zmc_m2[19872]: INF [Starting Capture]
Dec 7 10:48:19 tanserver zma_m2[24819]: INF [BackDoor: 4357517 - Gone into prealarm state]
Dec 7 10:48:19 tanserver zma_m2[24819]: INF [BackDoor: 4357518 - Gone into alarm state]
Dec 7 10:48:20 tanserver zma_m2[24819]: INF [BackDoor: 4357541 - Gone into alert state]
Dec 7 10:48:20 tanserver zma_m2[24819]: INF [BackDoor: 4357544 - Gone back into alarm state]
Dec 7 10:48:20 tanserver zma_m2[24819]: INF [BackDoor: 4357552 - Gone into alert state]
Dec 7 10:48:20 tanserver zma_m2[24819]: INF [BackDoor: 4357553 - Gone back into alarm state]
Dec 7 10:48:21 tanserver zma_m2[24819]: INF [BackDoor: 4357561 - Gone into alert state]
Dec 7 10:48:21 tanserver zma_m2[24819]: INF [BackDoor: 4357562 - Gone back into alarm state]
Dec 7 10:48:35 tanserver zma_m2[24819]: INF [BackDoor: 4357707 - Gone into alert state]
Dec 7 10:48:35 tanserver zma_m2[24819]: INF [BackDoor: 4357712 - Left alarm state (1729) - 200(185) images]
Dec 7 10:48:36 tanserver zma_m2[24819]: INF [BackDoor: 4357715 - Gone into prealarm state]
Dec 7 10:48:36 tanserver zma_m2[24819]: INF [BackDoor: 4357716 - Gone into alarm state]
Dec 7 10:48:36 tanserver zma_m2[24819]: INF [BackDoor: 4357718 - Gone into alert state]
Dec 7 10:48:36 tanserver zma_m2[24819]: INF [BackDoor: 4357723 - Left alarm state (1730) - 13(3) images]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357730 - Gone into prealarm state]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357731 - Gone into alarm state]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357732 - Gone into alert state]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357737 - Left alarm state (1731) - 12(2) images]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357744 - Gone into prealarm state]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357745 - Gone into alarm state]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357746 - Gone into alert state]
Dec 7 10:48:37 tanserver zma_m2[24819]: INF [BackDoor: 4357751 - Left alarm state (1732) - 12(2) images]
Dec 7 10:48:43 tanserver zma_m2[24819]: INF [BackDoor: 4358000 - Processing at 5.92 fps]
Dec 7 10:49:58 tanserver zmc_m2[19872]: INF [Got TERM signal, exiting]
Dec 7 10:49:59 tanserver zmc_m2[20013]: INF [Debug Level = 0, Debug Log = <none>]
Dec 7 10:49:59 tanserver zmc_m2[20013]: INF [Starting Capture]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358644 - Gone into prealarm state]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358645 - Gone into alarm state]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358671 - Gone into alert state]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358674 - Gone back into alarm state]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358678 - Gone into alert state]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358683 - Left alarm state (1733) - 44(31) images]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358685 - Gone into prealarm state]
Dec 7 10:50:28 tanserver zma_m2[24819]: INF [BackDoor: 4358686 - Gone into alarm state]
Dec 7 10:50:34 tanserver zma_m2[24819]: INF [BackDoor: 4358795 - Gone into alert state]
Dec 7 10:50:34 tanserver zma_m2[24819]: INF [BackDoor: 4358800 - Left alarm state (1734) - 120(110) images]
Dec 7 10:50:34 tanserver zma_m2[24819]: INF [BackDoor: 4358804 - Gone into prealarm state]
Dec 7 10:50:34 tanserver zma_m2[24819]: INF [BackDoor: 4358805 - Gone into alarm state]
Dec 7 10:50:34 tanserver zma_m2[24819]: INF [BackDoor: 4358826 - Gone into alert state]
Dec 7 10:50:34 tanserver zma_m2[24819]: INF [BackDoor: 4358828 - Gone back into alarm state]
Dec 7 10:50:35 tanserver zma_m2[24819]: INF [BackDoor: 4358838 - Gone into alert state]
Dec 7 10:50:35 tanserver zma_m2[24819]: INF [BackDoor: 4358843 - Left alarm state (1735) - 44(32) images]
Dec 7 10:50:35 tanserver zma_m2[24819]: INF [BackDoor: 4358850 - Gone into prealarm state]
Dec 7 10:50:35 tanserver zma_m2[24819]: INF [BackDoor: 4358851 - Gone into alarm state]
Dec 7 10:50:35 tanserver zma_m2[24819]: INF [BackDoor: 4358852 - Gone into alert state]
Dec 7 10:50:35 tanserver zma_m2[24819]: INF [BackDoor: 4358857 - Left alarm state (1736) - 12(2) images]
Dec 7 10:50:36 tanserver zma_m2[24819]: INF [BackDoor: 4359000 - Processing at 8.85 fps]
Dec 7 10:50:59 tanserver zmc_m2[20013]: INF [Got TERM signal, exiting]
Dec 7 10:50:59 tanserver zmc_m2[20023]: INF [Debug Level = 0, Debug Log = <none>]
Dec 7 10:50:59 tanserver zmc_m2[20023]: INF [Starting Capture]
Dec 7 10:51:25 tanserver zma_m2[24819]: INF [BackDoor: 4360000 - Processing at 20.41 fps]
Dec 7 10:51:39 tanserver zma_m2[24819]: INF [BackDoor: 4361000 - Processing at 71.43 fps]
Dec 7 10:51:53 tanserver zma_m2[24819]: INF [BackDoor: 4362000 - Processing at 71.43 fps]
Dec 7 10:52:25 tanserver zma_m2[24819]: INF [BackDoor: 4363000 - Processing at 31.25 fps]
Dec 7 10:52:45 tanserver zma_m2[24819]: INF [BackDoor: 4364000 - Processing at 50.00 fps]
Dec 7 10:53:09 tanserver zma_m2[24819]: INF [BackDoor: 4365000 - Processing at 41.67 fps]
Dec 7 10:53:29 tanserver zma_m2[24819]: INF [BackDoor: 4366000 - Processing at 50.00 fps]
Dec 7 10:53:43 tanserver zma_m2[24819]: INF [BackDoor: 4367000 - Processing at 71.43 fps]
Dec 7 10:53:53 tanserver zma_m2[24819]: INF [BackDoor: 4368000 - Processing at 100.00 fps]
Dec 7 10:54:02 tanserver zma_m2[24819]: INF [BackDoor: 4369000 - Processing at 111.11 fps]
Dec 7 10:54:15 tanserver zma_m2[24819]: INF [BackDoor: 4370000 - Processing at 76.92 fps]
Dec 7 10:54:27 tanserver zma_m2[24819]: INF [BackDoor: 4371000 - Processing at 83.33 fps]
Dec 7 10:54:30 tanserver zmc_m2[19865]: INF [BackDoor: 1000 - Capturing at 2.26 fps]
Dec 7 10:54:39 tanserver zma_m2[24819]: INF [BackDoor: 4372000 - Processing at 83.33 fps]
Dec 7 10:54:51 tanserver zma_m2[24819]: INF [BackDoor: 4373000 - Processing at 83.33 fps]
Dec 7 10:55:02 tanserver zma_m2[24819]: INF [BackDoor: 4374000 - Processing at 90.91 fps]
Dec 7 10:55:13 tanserver zma_m2[24819]: INF [BackDoor: 4375000 - Processing at 90.91 fps]
Dec 7 10:55:27 tanserver zma_m2[24819]: INF [BackDoor: 4376000 - Processing at 71.43 fps]
Dec 7 10:55:40 tanserver zmc_m2[20023]: INF [BackDoor: 1000 - Capturing at 3.56 fps]
Dec 7 10:55:41 tanserver zma_m2[24819]: INF [BackDoor: 4377000 - Processing at 71.43 fps]
Dec 7 10:55:50 tanserver zma_m2[24819]: INF [BackDoor: 4378000 - Processing at 111.11 fps]
Dec 7 10:55:59 tanserver zma_m2[24819]: INF [BackDoor: 4379000 - Processing at 111.11 fps]
Dec 7 10:56:08 tanserver zma_m2[24819]: INF [BackDoor: 4380000 - Processing at 111.11 fps]
Dec 7 10:56:20 tanserver zma_m2[24819]: INF [BackDoor: 4381000 - Processing at 83.33 fps]
Dec 7 10:56:31 tanserver zma_m2[24819]: INF [BackDoor: 4382000 - Processing at 90.91 fps]
Dec 7 10:56:45 tanserver zma_m2[24819]: INF [BackDoor: 4383000 - Processing at 71.43 fps]
Dec 7 10:57:03 tanserver zma_m2[24819]: INF [BackDoor: 4384000 - Processing at 55.56 fps]
Dec 7 10:57:18 tanserver zma_m2[24819]: INF [BackDoor: 4385000 - Processing at 66.67 fps]
Dec 7 10:57:34 tanserver zma_m2[24819]: INF [BackDoor: 4386000 - Processing at 62.50 fps]
Dec 7 10:57:54 tanserver zma_m2[24819]: INF [BackDoor: 4387000 - Processing at 50.00 fps]
Dec 7 10:58:19 tanserver zmc_m2[19865]: INF [BackDoor: 2000 - Capturing at 4.37 fps]
Dec 7 10:58:37 tanserver zma_m2[24819]: INF [BackDoor: 4388000 - Processing at 23.26 fps]
Dec 7 10:59:02 tanserver zma_m2[24819]: INF [BackDoor: 4389000 - Processing at 40.00 fps]
Dec 7 10:59:14 tanserver zma_m2[24819]: INF [BackDoor: 4390000 - Processing at 83.33 fps]
Dec 7 10:59:22 tanserver zmc_m2[20023]: INF [BackDoor: 2000 - Capturing at 4.50 fps]
Dec 7 10:59:25 tanserver zma_m2[24819]: INF [BackDoor: 4391000 - Processing at 90.91 fps]
Dec 7 10:59:39 tanserver zma_m2[24819]: INF [BackDoor: 4392000 - Processing at 71.43 fps]
Dec 7 10:59:56 tanserver zma_m2[24819]: INF [BackDoor: 4393000 - Processing at 58.82 fps]
A bad event.
Id 1730
Name Backdoor1730
Monitor BackDoor (2)
Cause Motion
Time 12/31 18:00:00
Duration 17282602.71
Frames 13
Alarm Frames 3
Total Score 160
Avg. Score 53
Max. Score 93
Archived No
Frames
Frame events.
Frame Id Alarm Frame Time Stamp Time Delta Score
1 No 18:00:00 0.00 0
2 No 18:00:00 0.00 0
3 No 18:00:00 0.00 0
4 No 18:00:00 0.00 0
5 No 18:00:00 0.00 0
6 Yes 18:00:00 0.00 93
7 Yes 10:48:19 9,999,999.99 37
8 Yes 10:48:19 9,999,999.99 30
9 No 10:48:29 9,999,999.99 0
10 No 10:48:36 9,999,999.99 0
11 No 10:48:20 9,999,999.99 0
12 No 10:48:26 9,999,999.99 0
13 No 10:48:27 9,999,999.99 0
Posted: Wed Dec 07, 2005 5:07 pm
by zoneminder
This is really really strange.
A long shot, but have you tried doing
just in case it's a corrupted DB?
Phil
Posted: Wed Dec 07, 2005 5:15 pm
by mnmis
The mysqlcheck is OK.
I don't know. I think that the server and camera can't talk to each other and that is causing it. WIFI networking could be the cause.
When I get home, I'll try moving the antenna's to get a better signal.
Thanks.
