ok , i have gcc4 .
With FFMPEG cause error in make program. ( with or without patch)
Other program similar FFMPEG , for Zone Minder ?
For FFMPEG stuff : " >>>>> Fix The CODE <<<<< " )
Alternative for FFMPEG.
i would suggest before you make a statement like that, that you reseach that ffmpeg is beta software and a new version is released virtually every day. You can build zm not to use ffmpeg which will solve your problem or build against a version of ffmpeg that has been tested with zmFor FFMPEG stuff : " >>>>> Fix The CODE <<<<< " )
0.4.8
James
James Wilson
