i have configured & compiled the program without errors !
I connect with mozilla at index.php:
Fatal error: Call to undefined function: session_start() /srv/www/htdocs/zm.php on line 159
The File info.php :
PHP Version 4.4.0
System Linux linux 2.6.13-15-default #1 Tue Sep 13 14:56:15 UTC 2005 i686
Build Date Sep 13 2005 02:16:37
Configure Command './configure' '--prefix=/usr' '--datadir=/usr/share/php' '--mandir=/usr/share/man' '--bindir=/usr/bin' '--libdir=/usr/share' '--includedir=/usr/include' '--sysconfdir=/etc' '--with-_lib=lib' '--with-config-file-path=/etc' '--with-exec-dir=/usr/lib/php/bin' '--disable-debug' '--enable-inline-optimization' '--enable-memory-limit' '--enable-magic-quotes' '--enable-safe-mode' '--enable-sigchild' '--disable-ctype' '--disable-session' '--without-mysql' '--disable-cli' '--without-pear' '--with-openssl' '--with-apxs2=/usr/sbin/apxs2-prefork' 'i586-suse-linux'
Server API Apache 2.0 Handler
Virtual Directory Support disabled
Configuration File (php.ini) Path /etc/php.ini
PHP API 20020918
PHP Extension 20020429
Zend Extension 20050606
Debug Build no
Zend Memory Manager enabled
Thread Safety disabled
Registered PHP Streams php, http, ftp, https, ftps
This program makes use of the Zend Scripting Language Engine:
Zend Engine v1.3.0, Copyright (c) 1998-2004 Zend Technologies
PHP Credits
Configuration
PHP Core
Directive Local Value Master Value
allow_call_time_pass_reference On On
allow_url_fopen On On
always_populate_raw_post_data Off Off
arg_separator.input & &
arg_separator.output & &
asp_tags Off Off
auto_append_file no value no value
auto_prepend_file no value no value
browscap no value no value
default_charset no value no value
default_mimetype text/html text/html
define_syslog_variables Off Off
disable_classes no value no value
disable_functions no value no value
display_errors On On
display_startup_errors Off Off
doc_root no value no value
docref_ext no value no value
docref_root no value no value
enable_dl On On
error_append_string no value no value
error_log no value no value
error_prepend_string no value no value
error_reporting 2039 2039
expose_php On On
extension_dir /usr/lib/php/extensions /usr/lib/php/extensions
file_uploads On On
gpc_order GPC GPC
highlight.bg #FFFFFF #FFFFFF
highlight.comment #FF8000 #FF8000
highlight.default #0000BB #0000BB
highlight.html #000000 #000000
highlight.keyword #007700 #007700
highlight.string #DD0000 #DD0000
html_errors On On
ignore_repeated_errors Off Off
ignore_repeated_source Off Off
ignore_user_abort Off Off
implicit_flush Off Off
include_path /usr/share/php /usr/share/php
log_errors Off Off
log_errors_max_len 1024 1024
magic_quotes_gpc On On
magic_quotes_runtime Off Off
magic_quotes_sybase Off Off
max_execution_time 30 30
max_input_time 60 60
memory_limit 8M 8M
open_basedir no value no value
output_buffering no value no value
output_handler no value no value
post_max_size 8M 8M
precision 12 12
register_argc_argv On On
register_globals Off Off
report_memleaks On On
safe_mode Off Off
safe_mode_exec_dir no value no value
safe_mode_gid Off Off
safe_mode_include_dir no value no value
sendmail_from no value no value
sendmail_path /usr/sbin/sendmail -t -i /usr/sbin/sendmail -t -i
serialize_precision 100 100
short_open_tag On On
SMTP localhost localhost
smtp_port 25 25
sql.safe_mode Off Off
track_errors Off Off
unserialize_callback_func no value no value
upload_max_filesize 2M 2M
upload_tmp_dir no value no value
user_dir no value no value
variables_order EGPCS EGPCS
xmlrpc_error_number 0 0
xmlrpc_errors Off Off
y2k_compliance On On
apache2handler
Apache Version Apache/2.0.54 (Linux/SUSE)
Apache API Version 20020903
Server Administrator cicco@lamio.com
Hostname:Port localhost:0
User/Group marco2(1002)/777
Max Requests Per Child: 0 - Keep Alive: on - Max Per Connection: 100
Timeouts Connection: 300 - Keep-Alive: 15
Virtual Server No
Server Root /srv/www
Loaded Modules core prefork http_core mod_so mod_access mod_actions mod_alias mod_auth mod_autoindex mod_cgi mod_dir mod_include mod_log_config mod_mime mod_negotiation mod_setenvif mod_status mod_userdir mod_asis mod_imap sapi_apache2 mod_perl
engine 1 1
last_modified 0 0
xbithack 0 0
Apache Environment
Variable Value
HTTP_ACCEPT image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, */*
HTTP_ACCEPT_LANGUAGE it
HTTP_ACCEPT_ENCODING gzip, deflate
HTTP_USER_AGENT Mozilla/4.0 (compatible; MSIE 6.0; Windows 98; snprtz|T04717348901012; .NET CLR 1.1.4322)
HTTP_HOST 10.0.0.2
HTTP_CONNECTION Keep-Alive
PATH /sbin:/usr/sbin:/usr/local/sbin:/opt/gnome/sbin:/root/bin:/usr/local/bin:/usr/bin:/usr/X11R6/bin:/bin:/usr/games:/opt/gnome/bin:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
SERVER_SIGNATURE <address>Apache/2.0.54 (Linux/SUSE) Server at 10.0.0.2 Port 80</address>
SERVER_SOFTWARE Apache/2.0.54 (Linux/SUSE)
SERVER_NAME 10.0.0.2
SERVER_ADDR 10.0.0.2
SERVER_PORT 80
REMOTE_ADDR 10.0.0.1
DOCUMENT_ROOT /srv/www/htdocs
SERVER_ADMIN cicco@lamio.com
SCRIPT_FILENAME /srv/www/htdocs/info.php
REMOTE_PORT 1733
GATEWAY_INTERFACE CGI/1.1
SERVER_PROTOCOL HTTP/1.1
REQUEST_METHOD GET
QUERY_STRING no value
REQUEST_URI /info.php
SCRIPT_NAME /info.php
HTTP Headers Information
HTTP Request Headers
HTTP Request GET /info.php HTTP/1.1
Accept image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, */*
Accept-Language it
Accept-Encoding gzip, deflate
User-Agent Mozilla/4.0 (compatible; MSIE 6.0; Windows 98; snprtz|T04717348901012; .NET CLR 1.1.4322)
Host 10.0.0.2
Connection Keep-Alive
HTTP Response Headers
X-Powered-By PHP/4.4.0
Keep-Alive timeout=15, max=99
Transfer-Encoding chunked
Content-Type text/html
mysql
MySQL Support enabled
Active Persistent Links 0
Active Links 0
Client API version 4.1.13
MYSQL_MODULE_TYPE none
MYSQL_SOCKET /var/lib/mysql/mysql.sock
MYSQL_INCLUDE no value
MYSQL_LIBS no value
mysql.allow_persistent Off Off
mysql.connect_timeout 60 60
mysql.default_host no value no value
mysql.default_password no value no value
mysql.default_port no value no value
mysql.default_socket no value no value
mysql.default_user no value no value
mysql.max_links Unlimited Unlimited
mysql.max_persistent Unlimited Unlimited
mysql.trace_mode Off Off
openssl
OpenSSL support enabled
OpenSSL Version OpenSSL 0.9.7g 11 Apr 2005
overload
User-Space Object Overloading Support enabled
pcre
PCRE (Perl Compatible Regular Expressions) Support enabled
PCRE Library Version 5.0 13-Sep-2004
pgsql
PostgreSQL Support enabled
PostgreSQL(libpq) Version 8.0.3
Multibyte character support enabled
SSL support enabled
Active Links 0
pgsql.allow_persistent Off Off
pgsql.auto_reset_persistent Off Off
pgsql.ignore_notice Off Off
pgsql.log_notice Off Off
pgsql.max_links Unlimited Unlimited
pgsql.max_persistent Unlimited Unlimited
posix
Revision $Revision: 1.51.2.4 $
standard
Regex Library Bundled library enabled
Dynamic Library Support enabled
Path to sendmail /usr/sbin/sendmail -t -i
assert.active 1 1
assert.bail 0 0
assert.callback no value no value
assert.quiet_eval 0 0
assert.warning 1 1
auto_detect_line_endings 0 0
default_socket_timeout 60 60
safe_mode_allowed_env_vars PHP_ PHP_
safe_mode_protected_env_vars LD_LIBRARY_PATH LD_LIBRARY_PATH
url_rewriter.tags a=href,area=href,frame=src,input=src,form=,fieldset= a=href,area=href,frame=src,input=src,form=,fieldset=
user_agent no value no value
tokenizer
Tokenizer Support enabled
xml
XML Support active
XML Namespace Support active
EXPAT Version 1.95.6
Additional Modules
Module Name
Environment
Variable Value
LESSKEY /etc/lesskey.bin
NNTPSERVER news
INFODIR /usr/local/info:/usr/share/info:/usr/info
MANPATH /usr/share/man:/usr/local/man:/usr/X11R6/man:/opt/gnome/share/man
HOSTNAME linux
GNOME2_PATH /usr/local:/opt/gnome:/usr
XKEYSYMDB /usr/X11R6/lib/X11/XKeysymDB
GPG_AGENT_INFO /tmp/gpg-86RRNA/S.gpg-agent:5374:1
HOST linux
SHELL /bin/bash
TERM xterm
DESKTOP_STARTUP_ID no value
STYLE Industrial
PROFILEREAD true
HISTSIZE 1000
GTK_RC_FILES /etc/opt/gnome/gtk/gtkrc:/root/.gtkrc-1.2-gnome2
GNOME_PATH :/opt/gnome:/usr
WINDOWID 50336518
QTDIR /usr/lib/qt3
XSESSION_IS_UP yes
GROFF_NO_SGR yes
JRE_HOME /usr/lib/jvm/jre
USER root
LD_LIBRARY_PATH /usr/lib:
GNOME_ICON_PATH /usr/share/images:/usr/share/YaST2/theme/current/icons/48x48/apps:/opt/kde3/share/icons/crystalsvg/32x32/apps:/opt/kde3/share/icons/crystalsvg/32x32/devices:/opt/kde3/share/icons/crystalsvg/32x32/mimetypes:/opt/kde3/share/icons/crystalsvg/32x32/filesystems:/opt/kde3/share/icons/crystalsvg/32x32/actions:/opt/kde3/share/icons/crystalsvg/48x48/apps:/opt/kde3/share/icons/crystalsvg/48x48/devices:/opt/kde3/share/icons/crystalsvg/48x48/mimetypes:/opt/kde3/share/icons/crystalsvg/48x48/filesystems:/opt/kde3/share/icons/crystalsvg/48x48/actions:/opt/gnome/share/icons/gnome/48x48/apps:/opt/gnome/share/icons/gnome/32x32/apps:/opt/gnome/share/pixmaps
LS_COLORS no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
DESKTOP_LAUNCH gnome-open
OPENWINHOME /usr/openwin
XNLSPATH /usr/X11R6/lib/X11/nls
HOSTTYPE i386
GNOME_KEYRING_SOCKET /tmp/keyring-ivo8Ec/socket
KDEDIR /opt/kde3
FROM_HEADER no value
USERNAME root
SESSION_MANAGER local/linux:/tmp/.ICE-unix/5319
PAGER less
XDG_CONFIG_DIRS /usr/local/etc/xdg/:/etc/xdg/:/etc/opt/gnome/xdg/
MINICOM -c on
GNOMEDIR /opt/gnome
DESKTOP_SESSION gnome
CPU i686
JAVA_BINDIR /usr/lib/jvm/jre/bin
GDM_XSERVER_LOCATION local
INPUTRC /etc/inputrc
PWD /usr/local/bin
JAVA_HOME /usr/lib/jvm/jre
XMODIFIERS @im=local
LANG POSIX
PYTHONSTARTUP /etc/pythonstart
KDEDIRS /opt/gnome/share/dist/kde-preconf
GDMSESSION gnome
TEXINPUTS :::/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX:/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX:/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX
SHLVL 2
HOME /root
LESS_ADVANCED_PREPROCESSOR no
OSTYPE linux
LS_OPTIONS -a -N --color=tty -T 0
XCURSOR_THEME Industrial
GNOME_DESKTOP_SESSION_ID Default
WINDOWMANAGER /usr/bin/dbus-launch --sh-syntax --exit-with-session /usr/X11R6/bin/gnome
GTK_PATH /usr/local/lib/gtk-2.0:/opt/gnome/lib/gtk-2.0:/usr/lib/gtk-2.0
LESS -M -I
MACHTYPE i686-suse-linux
LOGNAME root
DBUS_SESSION_BUS_ADDRESS unix:abstract=/tmp/dbus-Ns1d1AjCVC,guid=33569c431539b26dcd299089e0703f00
XDG_DATA_DIRS /usr/local/share/:/usr/share/:/etc/opt/kde3/share/:/opt/kde3/share/:/opt/gnome/share/
LC_CTYPE it_IT.UTF-8
ACLOCAL_FLAGS -I /opt/gnome/share/aclocal
PKG_CONFIG_PATH /usr/local/lib/pkgconfig:/usr/local/share/pkgconfig:/usr/lib/pkgconfig:/usr/share/pkgconfig:/opt/kde3/lib/pkgconfig:/opt/gnome/lib/pkgconfig:/opt/gnome/lib/pkgconfig:/opt/gnome/share/pkgconfig
LESSOPEN lessopen.sh %s
INFOPATH /usr/local/info:/usr/share/info:/usr/info:/opt/gnome/share/info
DISPLAY :0.0
LESSCLOSE lessclose.sh %s %s
G_BROKEN_FILENAMES 1
JAVA_ROOT /usr/lib/jvm/jre
COLORTERM gnome-terminal
XAUTHORITY /root/.Xauthority
_ /usr/sbin/httpd2
PHP Variables
Variable Value
_SERVER["HTTP_ACCEPT"] image/gif, image/x-xbitmap, image/jpeg, image/pjpeg, application/x-shockwave-flash, */*
_SERVER["HTTP_ACCEPT_LANGUAGE"] it
_SERVER["HTTP_ACCEPT_ENCODING"] gzip, deflate
_SERVER["HTTP_USER_AGENT"] Mozilla/4.0 (compatible; MSIE 6.0; Windows 98; snprtz|T04717348901012; .NET CLR 1.1.4322)
_SERVER["HTTP_HOST"] 10.0.0.2
_SERVER["HTTP_CONNECTION"] Keep-Alive
_SERVER["PATH"] /sbin:/usr/sbin:/usr/local/sbin:/opt/gnome/sbin:/root/bin:/usr/local/bin:/usr/bin:/usr/X11R6/bin:/bin:/usr/games:/opt/gnome/bin:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
_SERVER["SERVER_SIGNATURE"] <address>Apache/2.0.54 (Linux/SUSE) Server at 10.0.0.2 Port 80</address>
_SERVER["SERVER_SOFTWARE"] Apache/2.0.54 (Linux/SUSE)
_SERVER["SERVER_NAME"] 10.0.0.2
_SERVER["SERVER_ADDR"] 10.0.0.2
_SERVER["SERVER_PORT"] 80
_SERVER["REMOTE_ADDR"] 10.0.0.1
_SERVER["DOCUMENT_ROOT"] /srv/www/htdocs
_SERVER["SERVER_ADMIN"] cicco@lamio.com
_SERVER["SCRIPT_FILENAME"] /srv/www/htdocs/info.php
_SERVER["REMOTE_PORT"] 1733
_SERVER["GATEWAY_INTERFACE"] CGI/1.1
_SERVER["SERVER_PROTOCOL"] HTTP/1.1
_SERVER["REQUEST_METHOD"] GET
_SERVER["QUERY_STRING"] no value
_SERVER["REQUEST_URI"] /info.php
_SERVER["SCRIPT_NAME"] /info.php
_SERVER["PHP_SELF"] /info.php
_SERVER["PATH_TRANSLATED"] /srv/www/htdocs/info.php
_SERVER["argv"] Array
_SERVER["argc"] 0
_ENV["LESSKEY"] /etc/lesskey.bin
_ENV["NNTPSERVER"] news
_ENV["INFODIR"] /usr/local/info:/usr/share/info:/usr/info
_ENV["MANPATH"] /usr/share/man:/usr/local/man:/usr/X11R6/man:/opt/gnome/share/man
_ENV["HOSTNAME"] linux
_ENV["GNOME2_PATH"] /usr/local:/opt/gnome:/usr
_ENV["XKEYSYMDB"] /usr/X11R6/lib/X11/XKeysymDB
_ENV["GPG_AGENT_INFO"] /tmp/gpg-86RRNA/S.gpg-agent:5374:1
_ENV["HOST"] linux
_ENV["SHELL"] /bin/bash
_ENV["TERM"] xterm
_ENV["DESKTOP_STARTUP_ID"] no value
_ENV["STYLE"] Industrial
_ENV["PROFILEREAD"] true
_ENV["HISTSIZE"] 1000
_ENV["GTK_RC_FILES"] /etc/opt/gnome/gtk/gtkrc:/root/.gtkrc-1.2-gnome2
_ENV["GNOME_PATH"] :/opt/gnome:/usr
_ENV["WINDOWID"] 50336518
_ENV["QTDIR"] /usr/lib/qt3
_ENV["XSESSION_IS_UP"] yes
_ENV["GROFF_NO_SGR"] yes
_ENV["JRE_HOME"] /usr/lib/jvm/jre
_ENV["USER"] root
_ENV["LD_LIBRARY_PATH"] /usr/lib:
_ENV["GNOME_ICON_PATH"] /usr/share/images:/usr/share/YaST2/theme/current/icons/48x48/apps:/opt/kde3/share/icons/crystalsvg/32x32/apps:/opt/kde3/share/icons/crystalsvg/32x32/devices:/opt/kde3/share/icons/crystalsvg/32x32/mimetypes:/opt/kde3/share/icons/crystalsvg/32x32/filesystems:/opt/kde3/share/icons/crystalsvg/32x32/actions:/opt/kde3/share/icons/crystalsvg/48x48/apps:/opt/kde3/share/icons/crystalsvg/48x48/devices:/opt/kde3/share/icons/crystalsvg/48x48/mimetypes:/opt/kde3/share/icons/crystalsvg/48x48/filesystems:/opt/kde3/share/icons/crystalsvg/48x48/actions:/opt/gnome/share/icons/gnome/48x48/apps:/opt/gnome/share/icons/gnome/32x32/apps:/opt/gnome/share/pixmaps
_ENV["LS_COLORS"] no=00:fi=00:di=01;34:ln=00;36:pi=40;33:so=01;35:do=01;35:bd=40;33;01:cd=40;33;01:or=40;31:ex=00;32:*.cmd=00;32:*.exe=01;32:*.com=01;32:*.bat=01;32:*.btm=01;32:*.dll=01;32:*.tar=00;31:*.tbz=00;31:*.tgz=00;31:*.rpm=00;31:*.deb=00;31:*.arj=00;31:*.taz=00;31:*.lzh=00;31:*.zip=00;31:*.zoo=00;31:*.z=00;31:*.Z=00;31:*.gz=00;31:*.bz2=00;31:*.tb2=00;31:*.tz2=00;31:*.tbz2=00;31:*.avi=01;35:*.bmp=01;35:*.fli=01;35:*.gif=01;35:*.jpg=01;35:*.jpeg=01;35:*.mng=01;35:*.mov=01;35:*.mpg=01;35:*.pcx=01;35:*.pbm=01;35:*.pgm=01;35:*.png=01;35:*.ppm=01;35:*.tga=01;35:*.tif=01;35:*.xbm=01;35:*.xpm=01;35:*.dl=01;35:*.gl=01;35:*.wmv=01;35:*.aiff=00;32:*.au=00;32:*.mid=00;32:*.mp3=00;32:*.ogg=00;32:*.voc=00;32:*.wav=00;32:
_ENV["DESKTOP_LAUNCH"] gnome-open
_ENV["OPENWINHOME"] /usr/openwin
_ENV["XNLSPATH"] /usr/X11R6/lib/X11/nls
_ENV["HOSTTYPE"] i386
_ENV["GNOME_KEYRING_SOCKET"] /tmp/keyring-ivo8Ec/socket
_ENV["KDEDIR"] /opt/kde3
_ENV["FROM_HEADER"] no value
_ENV["USERNAME"] root
_ENV["SESSION_MANAGER"] local/linux:/tmp/.ICE-unix/5319
_ENV["PAGER"] less
_ENV["XDG_CONFIG_DIRS"] /usr/local/etc/xdg/:/etc/xdg/:/etc/opt/gnome/xdg/
_ENV["MINICOM"] -c on
_ENV["GNOMEDIR"] /opt/gnome
_ENV["PATH"] /sbin:/usr/sbin:/usr/local/sbin:/opt/gnome/sbin:/root/bin:/usr/local/bin:/usr/bin:/usr/X11R6/bin:/bin:/usr/games:/opt/gnome/bin:/opt/kde3/bin:/usr/lib/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin
_ENV["DESKTOP_SESSION"] gnome
_ENV["CPU"] i686
_ENV["JAVA_BINDIR"] /usr/lib/jvm/jre/bin
_ENV["GDM_XSERVER_LOCATION"] local
_ENV["INPUTRC"] /etc/inputrc
_ENV["PWD"] /usr/local/bin
_ENV["JAVA_HOME"] /usr/lib/jvm/jre
_ENV["XMODIFIERS"] @im=local
_ENV["LANG"] POSIX
_ENV["PYTHONSTARTUP"] /etc/pythonstart
_ENV["KDEDIRS"] /opt/gnome/share/dist/kde-preconf
_ENV["GDMSESSION"] gnome
_ENV["TEXINPUTS"] :::/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX:/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX:/root/.TeX:/usr/share/doc/.TeX:/usr/doc/.TeX
_ENV["SHLVL"] 2
_ENV["HOME"] /root
_ENV["LESS_ADVANCED_PREPROCESSOR"] no
_ENV["OSTYPE"] linux
_ENV["LS_OPTIONS"] -a -N --color=tty -T 0
_ENV["XCURSOR_THEME"] Industrial
_ENV["GNOME_DESKTOP_SESSION_ID"] Default
_ENV["WINDOWMANAGER"] /usr/bin/dbus-launch --sh-syntax --exit-with-session /usr/X11R6/bin/gnome
_ENV["GTK_PATH"] /usr/local/lib/gtk-2.0:/opt/gnome/lib/gtk-2.0:/usr/lib/gtk-2.0
_ENV["LESS"] -M -I
_ENV["MACHTYPE"] i686-suse-linux
_ENV["LOGNAME"] root
_ENV["DBUS_SESSION_BUS_ADDRESS"] unix:abstract=/tmp/dbus-Ns1d1AjCVC,guid=33569c431539b26dcd299089e0703f00
_ENV["XDG_DATA_DIRS"] /usr/local/share/:/usr/share/:/etc/opt/kde3/share/:/opt/kde3/share/:/opt/gnome/share/
_ENV["LC_CTYPE"] it_IT.UTF-8
_ENV["ACLOCAL_FLAGS"] -I /opt/gnome/share/aclocal
_ENV["PKG_CONFIG_PATH"] /usr/local/lib/pkgconfig:/usr/local/share/pkgconfig:/usr/lib/pkgconfig:/usr/share/pkgconfig:/opt/kde3/lib/pkgconfig:/opt/gnome/lib/pkgconfig:/opt/gnome/lib/pkgconfig:/opt/gnome/share/pkgconfig
_ENV["LESSOPEN"] lessopen.sh %s
_ENV["INFOPATH"] /usr/local/info:/usr/share/info:/usr/info:/opt/gnome/share/info
_ENV["DISPLAY"] :0.0
_ENV["LESSCLOSE"] lessclose.sh %s %s
_ENV["G_BROKEN_FILENAMES"] 1
_ENV["JAVA_ROOT"] /usr/lib/jvm/jre
_ENV["COLORTERM"] gnome-terminal
_ENV["XAUTHORITY"] /root/.Xauthority
_ENV["_"] /usr/sbin/httpd2
Where is the problem ??????
session_start
- zoneminder
- Site Admin
- Contact:
I don't think there is a ZM fix for this. Session_start is just a regular php function.
If you create a file like
Do you get the same error?
Phil
<?php
echo "Testing";
session_start();
Phil
Ive got the same issue. When I set up that test php I got:
Testing
Fatal error: Call to undefined function: session_start() in /srv/www/htdocs/zm/test.php on line 3
Effectively the same error I first got but with a different line number.
(I have noticed that when I try to get to phpMyAdmin I get a realted error:
phpMyAdmin - Error
Cannot load session extension. Please check your PHP configuration.
Josh
Testing
phpMyAdmin - Error
Josh
