Hi
I enable the mpeg option,and I add a file monitor in Function Parameter.
But websit can not display,because the server had exhausted memory.
why?
Is this right?
display mpeg file problem
cordel wrote:That's a good question.
What do your log's say?
On what kind of system?
Using what distribution?
Regards,
Corey
This information in my /var/log/messages file.
zmc_m4[3727]: ERR [Can't open /opt/download/foot.mpg: Permission denie
d]
zms[4375]: ERR [Shared memory not initialised by capture daemon]
Watchdog starting at 05/12/10 17:34:03
Watchdog pausing for 30 seconds
Can't get shared memory id '2053971969': No such file or directory
use zoneminder-1.21.4
You need to make sure the apache user can read and write to that directoryjhyoulin wrote:Code: Select all
zmc_m4[3727]: ERR [Can't open /opt/download/foot.mpg: Permission denie d] zms[4375]: ERR [Shared memory not initialised by capture daemon]
This issue is listed in the FAQ.jhyoulin wrote: and this in my /tmp/zmwatch.logI tried Fedora Core 3 & 4,but them had the same result.Code: Select all
Watchdog starting at 05/12/10 17:34:03 Watchdog pausing for 30 seconds Can't get shared memory id '2053971969': No such file or directory Can't get shared memory id '2053971969': No such file or directory Can't get shared memory id '2053971969': No such file or directory Can't get shared memory id '2053971969': No such file or directory Can't get shared memory id '2053971969': No such file or directory Can't get shared memory id '2053971969': No such file or directory
Regards,
Cordel
- zoneminder
- Site Admin
- Contact:
